Stuck in 4x4 after dead battery -SOLVED-
SwissBronco
Patrick
Switzerland
Jeep JK, JL, Hummer H1,
Hi helpers
I had a dead battery due to not driving the Bronco for a month.
After a good charge, it's stuck in 4x4. I can't change the drive mode, on startup it says service 4x4.
I have read that this can happen after a dead battery. Do I really have to go to the dealer to have the 4x4 module software reset? Is there any way around this?
Thanks for any help, Patrick
22 Outerbanks Sasy, 2.7
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
You could try disconnecting the battery (once its fully charged), then reconnecting it after 30sec or so. Some modules do flaky stuff when voltage gets low. There is a software update for the 4x4 module tho, might help in the future!
Fordified1
Bob
Mid South Texas
I definitely wouldn’t want to drive it to the dealer on dry pavement stuck in 4wd. in 4A maybe. Hopefully disconnecting the battery will let it reset.
SwissBronco
SwissBronco
Patrick
Switzerland
Thanks, sorry forgot to write, that was the first I did. Disconnected the battery overnight and gave the battery a good charge. Battery is fine.
Patrick
hemiblas
Roger
Aurora, Co
2023 base SAS Bronco, 2018 Rubi JL and JLU
Patrick
Now that the battery is in....start the Bronco, let the engine run for a bit and then stop it. Then disconnect the battery for 30 seconds and then reconnect.
Fordified1
Bob
Mid South Texas
Patrick
I would still try to disconnect the battery now that it’s fully charged for a minute and then hook it back up and see if that clears it.
SwissBronco
SwissBronco
Patrick
Switzerland
Will do so and let you know!
Good feedback!
ksdon
kansas
Ford is trying to expand it's on-site service. Some dealers have a limited range of services while others are equipped to do much more. I'd check if they can come to you.
BroncoAZ
Mitch
Mine isn’t stuck in 4x4, but after a month and a half of not using it the battery was down to 3.45 volts. I used my 7 amp Ctek charger for about 24 hours and the battery (surprisingly) seems ok. A week later I’m still getting all of these warnings when I start the truck. The truck is in the garage for winter storage, so it hasn’t left the driveway to possibly let things reset out on the road. I did try letting it idle up to temp then shutting it off and disconnecting the battery for 1 minute, all the warnings are still present.
Yes, my 2021 Bronco doesn’t have 5,000 miles yet. I have an employer provided work truck for daily use.
Ford Bronco Stuck in 4x4 after dead battery -SOLVED- IMG_7641
Ford Bronco Stuck in 4x4 after dead battery -SOLVED- IMG_7683
Ford Bronco Stuck in 4x4 after dead battery -SOLVED- IMG_7684
Ford Bronco Stuck in 4x4 after dead battery -SOLVED- IMG_7685
Ford Bronco Stuck in 4x4 after dead battery -SOLVED- IMG_7686
Ford Bronco Stuck in 4x4 after dead battery -SOLVED- IMG_7687
Ford Bronco Stuck in 4x4 after dead battery -SOLVED- IMG_7688
Bmadda
Wisconsin USA
Mine sets all those warnings when I let the battery go dead. Goes away after running for 10 minutes or so, or driving it a few blocks
BadlandsA51
Craig
Kansas
23 Badlands, Sasquatch, Lux Pkg, 72 Ranchero GT
Those messages are all set by the ABS module. Driving a short distance may reset them after ABS module sees wheel speed sensors, steering angle sensor, “talks” to other modules so it knows all is well with them.
Glade Runner
Everglades
VA
Yes
Everglades
What is causing bronco batteries to drain when not used?
