Stubby (shorter) antenna
jhruzek
Houston
2022 BRaptor, 2024 BRaptor
Anyone have interference with their TPMS with a replacement antenna?
JL8jeff
Ewing, NJ
No, I had to buy the tpms triggering device to get the computer to read the new oem sensors, but they're all working along with the stubby antenna.
RimrockPaul
Paul
Rimrock AZ
2021 Ford F250
I looked at a lottttt. Hi end, low end before changing. At first I was set on the stubby. Wanted to eliminate the whole look of the old antenna. But then I saw a comment from someone saying that aesthetically it didn’t look proportional to the vehicle. That changed it instantly for me personally. So I went on a hunt for a 13” height one. About the height of the windshield approx. ….maybe just a little shorter. I have not lost reception it’s is exactly the same if not better, and so far so good. It’s about half the size of the original OEM. There’s so many out there that you can change it up anytime you want. I also luv the squared off top. I know everyone has their own personal taste. But this is the one I have for now.
~Reese 🩶💁🏻‍♀️
Helical wound are more efficient. The longer the better. Like most things.
Zstngz
Stephen
Orlando
2012 Boss 302, Datsun Z, Merc E350
I only changed because of the car wash. I had grown accustomed to the original and really didn't mind it eventually.
KABQ
Aaron
Albuquerque, NM
This one has worked really well. Almost as good as the factory antenna and really impressive for its size. I'm a terrestrial radio guy, so it matters to me.
https://www.amazon.com/Compatible-F...9TVF7QSM&psc=1&ref_=pd_basp_bia_rpt_ba_s_1_sc
Edited to add a quick (oops, terrible) photo.
Update: I swapped the whippy antenna back on after upgrading speakers. The little antenna seems like it loses a whole octave of lower frequencies. I also got a ton of interference from my ditch lights, which is minimal with the long antenna.
CarGuy
CarGuy
New Jersey
2023 Ford Bronco
So how has your swap been working for you?
Not bad. I tend to listen to Sirius more that AM/FM. When listening FM, I do notice some stations dropping on a trip where the OEM antenna would hold on a bit longer. The stubby does grab HD radio. I don’t have enough data to know if better/worse/same as the OEM. Overall, I like it and worth the money. I’m also pleased not having it hit the garage overhang and door.
STX Bronco
South Texas
F150 SuperCrew 22 Badlands
Thanks for the info. I might check back down the road again. I use my fm radio quite a bit, so I am not sure I want to sacrifice any distance.
pillar406
Javier
www.keeseemotorcompany.com
2024 Bronco
Badass Bronc
Toronto, Canada
Dialtone
Twilight Zone
Bronco Big Bend Mid
