Strut tower bolt issue
BroncoRunner23
2023 Bronco
Wanted to see if anyone has had this issue and what you did
I installed a leveling kit and the strut bolts don’t stick out as much which makes since since the leveling plate takes some of the space
I have an ARB compressor mount from Grimm off roading which the support mounts bolt to one of the strut bolts.
So the leveling kit plus the compressor mount cause me to not have enough treads for me to have the bolt on all the way like the other ones.
I rather not buy a whole new mount for the compressor but will if I need to
any suggestions?
Ford Bronco Strut tower bolt issue IMG_3284
Ford Bronco Strut tower bolt issue IMG_3285
GI_Jo_Nathan
Jonathan
Yeah that's a tough one. Personally I think I would see either see if there is another hole or two further in that you could add another bracket to move that one too. Or drill another hole to move it to. Hard to say without getting in there. Definitely gonna take some fabri-cobling.
The official answer would be to knock the bolts out of the shock (they usually are just pressed in), and replace them with longer bolts.
You don't necessarily need new "press-in" bolts, you could use standard head bolts - just harder to get at to tighten since you'll need to be on both ends.
I've always heard you need to be able to see 2 complete threads on the bolt after the nut is tightened to ensure it's strong enough to hold. Even without the bracket your bolts aren't quite long enough for what you are running.
dgorsett
colorado
F250, Mustang, Explorer
Unofficial, that's like 2.5 outta 3 so 83%. So assuming the engineers have a 50% safety factor your good and I'd run it that way....for about two months, until it bugged me too much and I took @Brian_B s advice and installed (at least one) longer bolt(s).
BroncoRunner23
BroncoRunner23
2023 Bronco
thanks. I was debating taking of the leveling kit and calling it a day but wanted to avoid removing the strut. So prefer to avoid the
Stud swap also but good option
I was hoping there was something easier lol
I bit the bullet ordered a different compressor mount that doesn’t request it to mount to the bolt.
so we good now since the nut gets all the treads like it should
Hammerli22
Isuzu Rodeo
Curious what Mount did you finally wind up getting. I went with SDHC for that same reason.
BroncoRunner23
BroncoRunner23
2023 Bronco
I’m assuming you meant SDHQ ? If so I went it that one. I will say it cost more than other mounts but you can see why. I can probably hang from that mount haha.
I would recommend that mount over the other engine bay mounts
Hammerli22
Isuzu Rodeo
Cool, see my writeup on that mount somewhere on the forum
