Strut Hardware is Apparently Single Use
gwp
Greg
Winchester, Virginia
Harley Davidson FLTRUSE
I purchased 1.5” front perch collars from Broncbuster to level my Badsquatch following installation of a winch and heavy Icon bumper. This should fix my rake and make it dead level.
I thought I’d check with a couple of local shops regarding installation. On a lark I also spoke to the service manager at my dealer. Ford apparently advises replacement of fasteners used in the strut assembly - at $120 for the bunch I think this is an easy choice to make.
On an unrelated note they’ve ordered me a new transmission….
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
I know that the CV axle nuts are single use. Have not heard about the other strut bolts.
nottinbe
St. Louis, MO
Do you have part numbers? I need these fasteners too for an upcoming project.
gwp
gwp
Greg
Regrettably, I do not. Suggest contacting your dealer. In my case I’ve asked them to do the work. They’ve quoted faster and cheaper than off road shops near me. (Yeah, I’m surprised too).
In plan to have them do perches, tie rods, and transmission replacement in one shot.
BigBend530
Dominic
Oroville, CA
2022 Ford Bronco 2Dr.
With nylock and locking thread style nuts, Ford service manual always says to replace them. I tend to get new for some and locktite for others.
  • Like
Reactions: gwp
V1Rotate
Brevard, NC
2022 Wildtrak
Only hardware I’ve replaced were two lower control arm bolts and nuts as they came galled/messed up from the factory when I dropped my lowers to install my first lift. I’ve since had it all back apart twice and zero chance I’m wasting perfectly good money and hardware.. in reality most people reuse everything but I guess I can see why Ford would call it single use for liability
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I'd be in the poorhouse by now, if over the years replacing nuts and bolts on my vehicles after one use.
It's all a scam by Big Nuts to get us to waste money.
nottinbe
St. Louis, MO
If they are torque-to-yield fasteners I wouldn't want to reuse them. Anyone know if they are TTY or if there is some other reason they are being called out as single-use?
FreddieLee
Freddie
Bronco & Tesla M3
I've definitely reused mine. :censored:
MNBigfoot
MN
What did the quotes come in at?
