Stronger Battery / Optima's Yellow Top battery?
Bradley Thornton
Bradley
Hattiesburg MS
XS is a complete different level than Optima Battery with Optima Battery your buying the name. I said what I said.
Bradley Thornton
Bradley
Hattiesburg MS
If you go to the FAQ for the two batteries and see how they are tested you will find the XS is tested at a way higher standard.
The Xs D925 is tested at 32deg for CA the Odyssey is ran at 32deg for CCA on marine and the PC925 is in that class.
For people up north this could be a game changer on use in cold weather.
Mikerider
Washington
Raptor, Ranger, Mustang, Focus, Explorer
you might consider a portable power station for your needs more than an optima or other upgraded battery. Gives you a portable solution that isolates from the vehicle
I have a Bluetti AC180 and 2 Gooloo P600s that have worked great for additional power without the risk of drawing downs my vehicle battery. I use mine mostly for running my 12v fridge in the back of the bronco, but handy for many other needs also.
Tons of options on the market anything 300Wh and above should work well for air mattress pump and other camp needs.
https://www.amazon.com/BLUETTI-Port...x=portable+power+station,aps,155&sr=8-14&th=1
https://us.gooloo.com/products/p600?variant=41747282264260
BroncoAZ
Mitch
I have done a ton of research over the years on this subject if you want a great battery check XS batteries out.
https://4xspower.com
I really like the 4XS batteries. Unfortunately it looks like they went from a 5 year warranty to a 3 year warranty on their AGM starting batteries.
