I guess you could take it apart if you were short on space. There is a Bronco version and Jeep version. I'm not sure the door qty matters. https://topliftpros.com/pages/broncoDoes this lift fold up when not in use? Is it specifically for two door Broncos or is it for Jeeps but works for Broncos? How does it get around the rear roll bar? Do you have a link to their website?
Jason
Link: https://topliftpros.com/Does this lift fold up when not in use? Is it specifically for two door Broncos or is it for Jeeps but works for Broncos? How does it get around the rear roll bar? Do you have a link to their website?
Jason
Thanks for this. I have a low ceiling in the garage so every inch of savings helps.I find the top easier to re-install without the pins. Because there is no worry about the pins scratching something, breaking, or having to align the top perfectly when first setting it down on the body. With another person we set the top down and then slide if necessary to position the holes.
As @entomophile mentioned, grab the plastic pins with a pliers and then unscrew with a screwdriver. They screw on, so don't try to knock them out.
First time removing my hardtop, I removed the pins and have not missed them. Although without the pins you have to line up the mounting holes visually, and might have to push inward a bit on the hardtop, to better line up the holes when ratcheting down the mounting bolts.
I’m doing something g very similar and planning on using 2x4 like your picture. Why did you end up with the 1x4 aluminum?2x4s or hard foam insulation panels. Mine is suspended by a hoist but rests on a floating shelf of aluminum 1x4s with foam pipe wrap across top. Wood 2x4s was the prelim design.
The wood was much heavier and rough finish, I liked the aluminum because then I didn't also need a washer on the bottom with the wingnut. With the foam padding and plasti-dip spray on - the aluminum looks alot more "finished". I can rest the padded aluminum on the top while I remove it and then rest it on the roll bar while I "bolt up" each side. That and my OCD didn't like the look of the wood.I’m doing something g very similar and planning on using 2x4 like your picture. Why did you end up with the 1x4 aluminum?
thanks
totally agree. Can you provide more details on the aluminum and where you got it?The wood was much heavier and rough finish, I liked the aluminum because then I didn't also need a washer on the bottom with the wingnut. With the foam padding and plasti-dip spray on - the aluminum looks alot more "finished". I can rest the padded aluminum on the top while I remove it and then rest it on the roll bar while I "bolt up" each side. That and my OCD didn't like the look of the wood.
I got it at metalsupermarkets.com I can't find the email with the details - I'll keep looking to see if I have more details.totally agree. Can you provide more details on the aluminum and where you got it?
