Stock Goodyears throwing rocks
Bronco#2
Louisiana
2020 SD tremor
I know this has been covered but these tires throw tons of rocks. I have a gravel driveway that’s 100 yards long and every time I leave home, I throw no less than 10 rocks until it quits. At some point I’m going to need to regravel my driveway.
im ready to change to some bfg KO2, but will that even solve my problem?
For those who’ve changed tires, do you notice a significant difference?
Is it the tires or is it a poor fender design?
I’ve had A/T tires for 20 years and have never had issues like this.
MNBronc
Lutsen MN
2022 Bronco
You definitely need mud flaps with the Bronco
  • Like
Reactions: Fly
Bronco#2
Louisiana
2020 SD tremor
I have them and go rhino steps to block the rocks. It sounds like I’m taking fire every time I get going
Mdsuits
05 f350, 68 bronco 89 samurai
Get rid of the Goodyears and 98% of the rock chucking will go away.
Bronco#2
Louisiana
2020 SD tremor
What tire did you swap to where you saw a difference?
QUOTE="Mdsuits, post: 1856216, member: 19905"]
[/QUOTE]
AK SNO RIDER
Ty
Alaska
It's the tires, made noticeable by a vehicle that has the tires outside the body.
Changing tires is a good 90% reduction.
M/Ts will throw far less rocks but the ones they do throw will be bigger.
PSUTE
Western Maryland
Sierra
9-10 thousand miles and it reduces significantly...
Mdsuits
Bfg km3 but I’ve never had any tire throw rocks like the Goodyears.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
We have had multiple K02s and they definitly dont kick up as much rocks.
Fly by Nite
Walt
Pa
I'll likely put a layer of finer stone on my 600ft driveway. I have the standard 2A modified now. Considering 1B stone or maybe asphalt millings as a top coat.
I may be able to improve the present surface by going over it with a compactor, that will push the larger stones into the surface, maybe making them less likely to be picked up by the tires.
I should have my BaseSquatch in a couple of weeks, I'll have to see how it goes.
