Stiffer springs option?
broncosor
2022 Bronco Badlands
Looking at stiffer springs cause when fully packed for overlanding, my SAS Badlands is too soft and too much squat.
Eibach pro lift spring is not an option: it’s a leveling kit which provides more lift in the front. I am looking to combat squat, not adding squat.
There must be an option out there?
dgorsett
colorado
F250, Mustang, Explorer
Bikeric
Tulsa
2022 Badlands LUX on 37's
You might need to go with a combination of Eibach spring AND a perch collar on the rear to increase the spring preload.
broncosor
broncosor
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I suppose you have a 2.7 as well, so you already have the stiffest factory springs. I love the way my 2.3/2dr feels with 2.7/4dr springs.
The perch collar idea should help.
J.O.
Ford Fusion Ford F150
I think Eibach has a stiffer spring you can buy for this. I t will still provide the lift though. Maybe contact their customer service and see if they have any options.
da_jokker
Jeep Wrangler JKUR
I'm up against the same problem. And although perch collars would lift you the exact amount, there are two issues with them as I see it.
1) they're not changing your spring rate. By lifting the mounting base, yes your Bronco gains height, But your spring is still compressed, and therefore has lost some travel.
2) The whole argument of Purch collars was they are better than spacers because they did NOT change the geometry. In our case, that is a bad thing. Our Broncos are sitting lower than stock which means we have changed the geometry (For example my CVs and tie rods are horizontal). By way of their very existence, using a Purch collar would raise your Bronco, but leave your geometry squished.
Of course in the rear there really isn't any geometry, but in the front it's a different story.
My point, and the conclusion that I've come up with, is that the real fix, and really the only true fix is replace your suspension with adjustable coil overs.
The alternative, and luckily cheapest solution, would be to use spacers.
And like you, I was eyeballing the Eibach pro springs until someone installed them and they sagged really bad in the rear after loading up the cargo. From what I remember, someone said they were looking into some overland springs, so maybe just waiting until Eibach comes out with those.
OddBall88
Joseph
Ford Bronco
Can always re drill the shock bolt hole on the axle and gain up to 2”s of lift and still have the same travel out of the shock.
Lakelife36
Ben
Interior of BC
It's far too late now, but this comes back to the earlier assertions that Ford really effed up the multiple suspension options by not making the Hitachi suspension the overlanding/towing setup and the Bilstein suspensions the high-articulation crawling setup. At least then we could have made informed decisions around which trim we bought for our intended purpose.
Silver-Bolt
Eureka, MT
I am also on the hunt for a stiffer spring setup without going higher than the factory height. The problem I have encountered is not knowing what the factory springs are rated at. The springs themselves should be a standard configuration that either Eibach or Geiser make. Not knowing the factory spring rate makes it impossible to make a change. On my FJ the stock fronts were 500lb, I added and ARB bumper and winch and went up to a 650lb and it was perfect.
Ellis Family Garage
Brad
Auburn, Washington
'23 Bronco Badlands, '06 F150 FX4, '95 Lightning
Stiffer springs always seem like a good choice. There needs to be some clarity, such as is the rid fully loaded all the time or is it just on trips, how much weight has been added. These are a few of the questions that need to be addressed. A local spring shop should be able help and guide you towards the correct set up. One problem with adding beefier springs to accommodate for heavier loads without up grading the shocks is the shock design itself. The valving in stock or aftermarket shocks are designed for certain type of operating range. By adding stiffer springs to stock shocks may get you the load capacity and ride height but the stock shocks weren't designed to deal with added load weight and the different spring rates. It then reduced ride quality so the trade is one issue for another. Shop around ask a lot of questions. Stiffer springs could be the a good solution but a suspension package designed for your application might be the correct answer.
broncosor
broncosor
As far as I know any of the aftermarket suspension like kings are designed for the Bronco itself, not for a 800 lbs cargo. So yes the spring would be adjustable and there would be about 2-3in lift, but the problem you describe remains. Unless the compression adjustment know solved that. Anyway that’s 6 thousand or more installed which is a ton of money versus $500 springs.
broncosor
broncosor
I contacted Eibach, they were developing stiffer springs for the Bronco but they halted the development.
Edit: they paused it due to production delays, they actually still plan to release those.
Good news
Overlander22
jt
NorCal
2wd/2.7
I was leaning toward sumos but after hooking up trailer and driving I'm gonna have to mull it over some more. Sag wasn't as bad as expected (1 inch lower in rear, 1 inch higher in front) but the trailer weight throws the Bronco around (up and down) more than my previous tow vehicle. Gotta be the supple suspension on Badlands? Maybe stiffer springs are better that than sumos?
Ford Bronco Stiffer springs option? 20230419_115411_resized
