Steering wheel shake, seat vibrations
Thiskers
Georgia
Just picked up my Bronco (badlands Sasquatched) late last week. Had it on the interstate for the first time yesterday and noticed some decent vibrations in the car and the steering wheeling having some shaking back and forth. This started around 55 mph and got a little better at 65+ but was still noticable. Even felt my pant leg was vibrating around rubbing up against my leg. My old truck never had 35s or M/T tires. Felt like a balancing issue. Is this normal for this size/type tire or should it be riding pretty smooth on a flat surface? Wondering if I should take it in to the dealer for them to check on.
carrellslake
Oregon
2022 Ford Bronco
It should be very smooth. Have the dealership look at it.
I swapped out my Goodyear Wranglers for Falken Wildpeaks and they are smooth on the highway too.
MayhemMike
Mercury
Are you sure it wasn’t the lane safety device kicking in as you occasionally crossed over a lane marker?
Deleted member 32220
Guest
Drive it. It is likely flat spots on the tires from sitting god knows where for how long. They go away in 10-20 miles or so
Thiskers
Georgia
Thanks guys.
I had about 90 miles on it so far. It did sit about 3 weeks though from build to delivery. I just took it out on the highway again to get up to 80. Seems to be smoother feeling at 70-80 than 50-60. It felt better than yesterday so maybe the tires did have a flat spot that is working itself out. Our interstates suck for road quality which makes it tougher to tell, trying to find something that is a bit fresher paved. Still riding with more of a rough feeling than my 16 year old truck which was body on frame.
I noticed it was at 46 psi leaving the dealership. Aired down to 39 when I got it back home. After the vibrations/wheel shake I aired down to 36. I feel like that helped a tad.
Also checked the lane assist/alert vibration and made sure I was in the dead center of the lane so the bronco would read as green.
Dealership forgot to give me something so I'm going by to pick it up Friday. I'll talk to them about it then and see if they have a road force balancer they can put it through. When I did the bronco off road test drive thing, it seemed to ride smoother on the pavement but since that was mainly off-road I was never at a very high speed.
DrewBronc21
New York
2020 Subaru STi, 2024 M2
I just got 35” Ko2s and Sasquatch suspension installed on my Non Sas badlands balanced, alignment, etc. and I have pretty bad shaking, vibration in steering wheel, seat and floor on highway @ 75mph +. Not having had lifted 4x4s before, I figured this is normal but now I’m thinking to have the shop check and maybe rebalance tires. I have them @ 38-39 psi.
could the actual suspension be causing it or this would strictly be a tire balance thing?
Gilligans_off
Vince
Canada
2022 2 Dr Bronco Badlands Sas/lux
I'm in the same boat. I noticed a shudder under heavy load on takeoff in addition to the vibrations at speed. I hope it's just the tires and not the Driveshaft out of balance.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.
RainbowStix
A Big Island
Toyota Tacoma
If the shop just balanced them, it’s not that. Did they give you an alignment printout? Also may want to check the lug nuts, especially if you got new rims and they’re lug centric now.
zyglyrox
Cory
Cleveland
‘24 BB Sas / ‘21 Bronco Sport BB
Unfortunately the OEM Goodyears are kind of trash I’ve had mine rebalanced 4 times in 2900 miles.
MateriaTattoo
Nicholas
Pennsylvania
Subaru Impreza
Hey I’m having similar issues. I have a 21 Black Diamond. I had the wheels swapped with KMC724’s. Above 70 I get odd random shaking/vibrations. I’ve had the dealership look at it 3 times already. They can’t find any issues and seems to blame the tires, shape of the vehicle etc. had it balanced twice with about 12k miles on it.
Feel like I need a second opinion.
DrewBronc21
New York
Did you resolve? I added hubcentric rings and still having same issue. Once I get above 70 -80 on highway I will get random shaking, shuddering. It’s not severe but enough that I want it fixed. I made an appointment at a place with a Hunter road force balancer to get the tires rebalanced and check for defect. Will report back.
here’s a vid of the shake
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
Man this is why I dont wanna mess with my stock set up. My non SAS BL is smooth as silk at any speed. I hardly ever have my hands on the wheel lol
Rspayde
North Ga
2022 C/O Black Diamond
Thanks guys.
I am going to chalk it up to roads. My ranger feels like a damn tin can when I get it up around 75-80 on some of these less upkept stretches of highway GDOT has blessed us with.
DrewBronc21
New York
Took mine for Hunter Road Force balance and shop could NOT get the K02s to balance. Guy said the tires are defective I’m assuming this is my vibration issue. I’ve read that it’s a frequent issue. Shop is a Tire Rack recommended installer so I’m going to try and get an exchange from tire rack for a different tire.
