Steering wheel shake, seat vibrations
DrewBronc21
New York
2020 Subaru STi, 2024 M2
i swapped the KO2s for Nittos and road force balanced and vibration is gone. Returned the KO2s to Tire Rack for refnd
John94
Detroit
4dr Black Diamond Sas
Hey I’m having similar issues. I have a 21 Black Diamond. I had the wheels swapped with KMC724’s. Above 70 I get odd random shaking/vibrations. I’ve had the dealership look at it 3 times already. They can’t find any issues and seems to blame the tires, shape of the vehicle etc. had it balanced twice with about 12k miles on it.
Feel like I need a second opinion.
Any updates?
I get vibrations at highway speeds. Have swapped wheels and tires and still get them.
Dealer refuses to do anything
BigBendBW
Columbus, Ohio
Bronco Base Sasquatch
Just picked up my Bronco (badlands Sasquatched) late last week. Had it on the interstate for the first time yesterday and noticed some decent vibrations in the car and the steering wheeling having some shaking back and forth. This started around 55 mph and got a little better at 65+ but was still noticable. Even felt my pant leg was vibrating around rubbing up against my leg. My old truck never had 35s or M/T tires. Felt like a balancing issue. Is this normal for this size/type tire or should it be riding pretty smooth on a flat surface? Wondering if I should take it in to the dealer for them to check on.
You sure that isn’t a rebadged Jeep???
BigBendBW
Columbus, Ohio
Haha, thankfully it quit. Guess the tires had to round out after being strapped down.
Glad to hear it, I’ve not had any issue close to that so makes sense of there was a tire issue.
RednWhite89
Evan
DMV
1989 Bronco
Any updates?
I still have pretty bad vibration at 75-77mph. At 1500 miles I had all tires replaced under warranty because of the vibration. It was bad at 35 and 70mph. The new tire balancing got a little better from the initial road force balance attempt on the originals, but they really couldn't get the Goodyears balanced well. The low speed vibration is pretty much gone but the high speed just moved up a few mph.
I'm pretty convinced it's a combination of the tires and the balancing effort, but I have resigned myself to living with it since I don't think it'll improve unless I swap out the tires to a different brand.
Edit: I run at 35 PSI which does help a bit and hopefully it will kill the tires a bit sooner so I can justify replacing them to the wife. ;)
BuckyG
Missouri
I'm in the same boat. I noticed a shudder under heavy load on takeoff in addition to the vibrations at speed. I hope it's just the tires and not the Driveshaft out of balance.
I have the exact same problem on my 2023. So far we have rotated and balanced x 3. No luck. Road force test and replaced one tire through Ford. Replaced the front driveshaft. Replaced a torn boot on the front driveshaft. I think the vibration is there all the time but becomes noticeable around 55 mph to 70 mph. I can’t see any cupping on any of the tires and current mileage is 5,000. The dealership and Ford are really very attentive but we are running out of ideas. Any thoughts?
ManSquatch
Washington, DC
23' Bronco, 17' F250
I have been having the same issues. I changed my badlands 33's to the Roush 17" wheels with 35's. I originally put the sasquatch tires on and had bad vibrations. Had the tire shop swap them for KO2's and still had a vibration 65+. Took it to another shop for balancing and still having the problem. Wondering if its an issue with the drivetrain.
ummie4
Cody
New Jersey
Jeep Cherokee
17,000 miles on my factory sas tires the shaking was getting progressively worst the past 2,000 miles. finally took it in. One tire was way out of balance, shop remounted it on the rim. All 5 tires had to be re balanced. Shake is 95% gone now and down to an acceptable level. I just figure the factory tires wear bad. Guess Ill have to deal with it until I need to replace them. Shake from tire wear is hard to keep track of as its a progressive thing. I find myself trying to remember now if it was ever 100% perfect...
