Starlink mounting location question
DaddyO
Jules
Austin, Texas
2024 Bronco 4D 2.7L Sasquatch
I purchased a Starlink Mini for my 2024 Badlands 2.7L 4-Door Hardtop. I installed molle panels in my ceiling from front to back seat and would like to mount the Starlink inside on the ceiling. Do yall think the magnets will hold on the molle panel? I recently saw some equipment from VERITUS Van. Looked interesting. Thoughts? Comments?
Ford Bronco Starlink mounting location question IMG_4661
Ford Bronco Starlink mounting location question IMG_4660
Cobrafang
Thomas
GA
The issue with magnets is more of an issue on the mount. If they all 4 can stick to the mole panel then I think you will be fine with them. When I did this type of mount on my mole panels I went and drilled holes to match. My mount did not come with magnets so I had no choice.
Probably, depends on magnet strength more than anything. The dish isn’t very heavy.
wjlapier
PNW—East Side
‘25 Heritage
The Stargear magnet for our mini is super strong. I tested it on an Open Road shelf and it was stuck on there tight. We were happy to see the mini can link through the roof. Our next purchase will be something closer to the roof like metal2mountain swing down shelf or the Crow Molle that mounts between the front seats but up near the roof.
5POINT56
2024 Bronco Raptor
No issues with Starlink mounted inside the roof?
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
I run mine on top of my Attic Tray, through the MIC roof and it works great. I have tow straps, ropes and more in the Attic Tray, so the Starlink just naturally wedges in that space securely for me.
Nanuck
Georgia
2023 Ford Bronco
Any mounting suggestions if someone has a soft top?
I have the Revolink mount, and with some minor modification it works with the soft top.
Nanuck
Georgia
2023 Ford Bronco
Thanks. If you have any pictures, that would be great to see.
My hard top is on right now but pretend its canvas
Had to move the mount forward of center for the soft top to roll over it when rolling it all the way back - easy to just drill 2 new holes and reuse 2 existing ones
The C-brace/frame fit no issues at all. Just needed to move the mount forward a bit to clear
Ford Bronco Starlink mounting location question imag
Nanuck
Georgia
2023 Ford Bronco
Thanks!
DaddyO
DaddyO
Jules
Austin, Texas
i guess I’d have to put it ina case to add the magnets?
