Sta-Bar Disconnect issue 3rd time now
MileHighCitizen
Al
Denver
Bronco 2D 2.7
You have a 3 year bumper-to-bumper warranty, tell the dealer to unlost themselves and repair or replace what's broken.
This isn't a "you" problem, it's a them problem...make them take responsibility for their warranty that you paid for.
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
You are obviously right, but that doesn't mean we can't help get things fixed quicker.
1) Have you checked the battery terminals for tightness?
2) Have you checked the various ground points around the engine bay for tightness?
3) Have you checked the bolts that hold the fusebox to the body?
Past that, perhaps try a different dealer at this point, but what have they previously done:
1) Has the sta-bar itself been replaced?
2) Have any of the electronics that control the sta-bar been replaced?
Hopefully one of the more knowledgeable folks in the Ford service business can help you further.
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2026 Ram RHO
Most Jeep guys remove their electric sway bar disconnect on their Rubicon's after a few years and go manual. This is why.
BAFERD
Jason
2016 GMC Denali 2500HD
Is this even an option for the Bronco? Has anyone made a manual sway bar disconnect?
TripleB
Georgia
BAFERD
Jason
Fourd
Fourd
ROA
2009 Volvo V8 X90R
Any luck with a fix on this? I've had this issue since early June '22 up to this morning and it's totally random when this pops up. Stinks because it locks me out of 4wd and GOAT mode. First month took to nearest dealer and it didn't show and they said nothing mechanically wrong. Third month I took to dealer where I bought and they said Ford said needs software upgrade - appears to be pursuant to PDF Technical Bulletin linked above - and they did that but sure enough wasn't fixed.
mike8675309
Minnesota
There is a tsb. If they did that work, then did you bring it back for them to work on?
BAFERD
Jason
They updated the software to the most recent on the TSB. 3 weeks later here we are and it has done it a 4th time. This fucking sucks!!!
GABS
GA
F250
Hi was wondering if your dealer ever found a solution for this? After the long wait I was able to pick mine up from the dealer this past Wed, took it out this weekend for the first trip and didn't even make it off the pavement when this happened. Just wondering what I'm going to be faced with.
Ford Bronco Sta-Bar Disconnect issue 3rd time now Bronco Sta-Bar Servic
