Speed Compensated Volume...does it work for you?
CarGuy
New Jersey
2023 Ford Bronco
I've tried disabling and enabling every option (low/med/high) on the Speed Compensated Control, but it does not work. Does this work for anyone else? If so, does it display the volume going up/down or do you just hear it increasing/decreasing? I'm getting tired of constantly turning the volume up/down when driving. Thanks.
Mine works as well. Can’t really notice much at all with the top off or the soft top on, but with the hard top High is just a bit too much but Medium isn’t quite enough.
it won’t adjust the volume number like when you turn the volume dial, but it does make it louder as you go faster
HeliPilot
Kenny
CT
2022 2.7L SAS
Yeah, mine is a hardtop as well. Probably why I notice it. In mine, high is definitely too much, and med is almost too much.
Mdsuits
05 f350, 68 bronco 89 samurai
Works great….but I redid the whole sound system so you can actually hear it.
Brostango
Bay Area, CA
2005 F150 Crew, 2016 ATS Coupe
My works. 2022 4 door convertible with aftermarket system. Keys 200.4 & 500.1 using plug and play harness.
HighVelocity
Big Sky Country
Pinto
It doesn't seem to do anything, but I'm deaf in one ear and can't hear through the other.
buzzcutt2
FL
I've never noticed a difference and mine is set to high.
da_jokker
Jeep Wrangler JKUR
So it makes it louder when you drive? I thought it turns it down when you stop. I tend to turn it up when I'm driving, and down when I stop, even with that feature on.
Five-O Donut Hole
Northern Illinois
2012 Ford Raptor-Loaded-Original Owner
To be honest, now that you mention it, i have my adjusted to high and I'm not sure i hear any difference....🤷‍♂️
I’ve never noticed a difference with mine set to HIGH and have tried different settings as well. Thought maybe it was just me.
My 12’ Raptor with the crappy Sony audio has a speed compensated volume control that works way better than the B&O system.
1st 75th ranger
jeffrey
nj
it works for me and my soft top
CarGuy
CarGuy
New Jersey
2023 Ford Bronco
Suppose to do both.
