Speaker static when hit bumps
London
2024 ford bronco
Hello. I’ve been getting a static noise every time my 2024 bronco hits a bump. I’ve had it for 3 months and it seems to be slowly getting worse. It does the same on all modes and even with the volume turned down you can hear it when going over a bump. If I’m just sitting in my car not moving it’s fine. Anybody have any ideas on the problem or seen this before? Thanks
KABQ
Aaron
Albuquerque, NM
Check your connections
London
2024 ford bronco
Thanks. Yes seems like something is loose. It does it no matter which side the speakers are balanced on. Maybe a bad ground? Does anybody know where I would access these connections to check? Thanks
HotdogThud
mk6 gti, '21 MoarDoor
Wait is this on a stock vehicle, like you haven't upgraded the speakers or added amps or anything?
If so, yeah, bad ground, and make someone else sort that out under warranty.
London
2024 ford bronco
Yes stock with B & O speakers. I should bring it it then as it’s only a few months old.
mpeugeot
See if shaking the fusebox under the hood will recreate the problem. This has been a common issue with the Bronco fuse blocks not being as fully secured as they should be from the factory.
