GMRS radio static from headlight module
KermitBronco
Ian
So. Cal.
2023 Bronco Badlands
Has anyone else been experiencing this? Midlands 575 with ghost antenna. We diagnosed it and low and behold:
- Headlights off = perfection.
- Headlights on = crazy loud incessant static.
- Unplug the antenna (it's 50 watt and still works) = perfection
I've tried 4 ferrite cores on the antenna wire. No luck.
Ideas greatly welcome.
Felix808
SRV CA
How do you have your radio wired? Where is it mounted?
Bschurr
NY
Ferrite on the power wire - NOT antenna!
KermitBronco
KermitBronco
Ian
So. Cal.
Thanks for feedback. I think I may have omitted one key point that I updated in the original post - if I unplug the antenna, it works "perfectly" - I have ~300 feet of range and no static.
I mounted the MXT575 inside on a Mountains2Metal console molle panel and ran the power and antenna through the firewall grommet and then power is hardwired in and the antenna goes over to a Mountains2Metal mount on the passenger side.
Bschurr
NY
Have you tried a different antenna and still have static?
Perhaps your antenna, wire or termination is defective and causing the interference.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
I have the same radio. What is your squelch set at? Factory setting is 4, but depending on weather and other noise factors I find I need to set squelch at 8 or 9. I'm using a mxta26A antenna, and it's very sensitive. The factory 2db mag-mount needed lower squelch to RX medium strength signals. W/the bigger antenna I still get very remote garbled transmissions w/squelch nearly all the way up. LED lights DO generate RF noise. Add light bar and ditch lights and it just gets worse...that's what you got SQ for! I have noticed that this radio is kinda touchy when you 1st turn it on, then it settles down. After 10-15 min of use I can turn the SQ back down if I want. I live about 20mi from a repeater, and even w/SQ on 9 I never miss a transmission from it
Felix808
SRV CA
This ^^^^.
What happens when you use the supplied antenna?
KermitBronco
KermitBronco
Ian
So. Cal.
THANKS EVERYONE! Team effort + humble pie and the problem is solved. Correct guesses - we diagnosed that the light module was causing the interference but the real issue is defective cable. I pulled out another cable and no static. Thanks again! Rewiring tomorrow.
I'll be sharing details in a few weeks when we (finally) finish our build - it's a Badlands Sasquatch, Stealth wrap running 37" Trail Grapplers, Dana 44 Ultimate/Spicer 32 Xtreme splines, upcoming 74Weld Steering Rack and Camburg Racing KINETIK UCA/TA and Fox Racing Elite suspension tuned by Camburg (when the Fox stuff finally arrives) plus full American Adventure Lab interior, Heretic Studio lighting and a few more goodies so stoked to finally truly join the community.
Hope to meet people at Bronco Safari in a month!
