Spare Wheel brake lights
Jo.S.
Jo
Pa
mustang
I love the spare tire brake lights but I ordered a 24 outer with sasquatch which has 35 in wheels. When I look up spare tire brake lights, I haven't found any for a 24 or the sasquatch wheels. Is there any out there? Thanks
BlueBronco
DFW
Are you looking for aftermarket brake lights that mount behind and shine through the spare? If so, any '21-'23 that work with Squatch wheels will also work for a MY24.
Jo.S.
Jo.S.
Jo
Pa
mustang
Yes. Thank you for that info. Do you know if any places that sell them for the sasquatch wheel? That was my other issue. I only saw ones for the non sasquatch wheel.
Utah Todd
Todd
2023 BroncoBadlands 2 Door
I like this one on mine. I was able to remove the factory brake light that stuck up a little bit, and also folded back the rear seat headrest. This way I get a clearer view out the rear window.
Ford Bronco Spare Wheel brake lights IMG20230714204045
parropski
Vic
Civic
That looks clean.
Could you link the spare light?
Jo.S.
Jo.S.
Jo
Pa
mustang
Yes link please. I like that. Thanks
Deano Bronc
Dean
Winona Lake, IN
2022 Badlands
Was this a plug and play or did you need to spice into the taillight wires?
Utah Todd
Todd
Plug & play from deep in the Amazon!
Have Sasquatch rims on it now.
jhruzek
Houston
2022 BRaptor, 2024 BRaptor
I did same for my Braptor, but I had to cut/splice wires. The connector is different from a regular Bronco.
PEGB
Pete
RI
Eruption Green Badlands Sasquatch Hardtop 4 door
https://store.xkglow.com/catalog/pr...ke-running-reverse-and-turn-signal-functions/
I used this one. I’ve been on the fence about recommending it. Now that it’s installed I do like it, it’s just their install instructions and customer service are weak. They state:
“Bronco Models without towing package and separate turn signals will not have a running light feature”
It basically forces you to tap into your tow package wiring near your hitch to get full functionality. I live in the road salt northeast and this wasn’t a good option for me, so I figured out a better way tapping into tow module on driver side in the cargo area and pulled the reverse light from the drivers side rear signal. Works fantastic now.
Utah Todd
Todd
That looks clean.
Here is the link....
OFFROAD GAMERS Spare Tire Brake Light for Bronco Third Brake Light Plug & Play,Red LED Wheel Brake Light Compatible with Bronco 2021 2022 2023 -Present 2 Door or 4 Door… https://a.co/d/8y8JzvS
Jo.S.
Jo.S.
Jo
Pa
mustang
Thank you. Ended up getting one for Christmas. Now, if I had the bronco to put it on. Haha. Fingers crossed for a build date this week!
Shadowsquatch
GA
Cactus Grey 2-Door Wildtrak
I'm not sure if they just sent me the wrong one, but the connectors on this didn't match my 2023 Wildtrak. I'll be returning this, and probably go with the Oracle version.
Edit: The connectors don't fit if you follow the paper instructions (or what was sent with mine). There is a video I missed earlier that shows a person installing it on a Bronco. Ignore the paper instructions, you need to go through the access panel on the back of the tailgate. Fish the light connectors through the vent flaps in the tailgate and pull it towards the connector inside the tailgate. The adapters do fit there.
