- Thread starter
- #1
Have 35mm borne spacers (high quality hub centric billet) installed a few weeks ago at dealer - torqued down to 100 lbs in star pattern for Sasquatch. Waited until around 75 miles to do the initial retorque at a Firestone. Per directions. From what I’ve read there is a break in period and you need to retorque for safety reasons. Then only need to retorque per oil change going forward.
I asked Firestone if anything loosened and they said all wheels were pretty good minus one. They said that one of the lugs on the spacers literally fell off and hit the floor when they removed the wheel. Now I’ve grown a conscience. It was unclear if any other lugs were loose on that wheel or if maybe the mechanic who did the initial install just forgot to torque down one lug. I find it hard to believe it would come completely loose.
No I did not use loctite since the directions, like bora are for the retorque after initial install in lieu of loctite.
thoughts? Are some lugs generally loose during the break in period thus the recommendation to retorque around 100 miles? My gut says that maybe they forgot to torque one lug on initial install since it’s not as if it were loose a quarter turn it was basically all the way loosened.
Like is this bad? Normal? Or isolated incident that isn’t possible unless the mechanic forgot to torque down that one lug.
