Spacer on hub?
GorillaGrapplr
Tim
Wheeling WV
2021 Ford Bronco Badlands 2.3 Area 51
I just bought new rims. I went to put them on the bronco but they won't quite fit. There seems to be some metal spacer tabs on the hub. Any way around these. Ordered rims from trail built fell like its going to be difficult to return.
Ford Bronco Spacer on hub? 20221022_183919
Ford Bronco Spacer on hub? 20221022_183701
Ford Bronco Spacer on hub? 20221022_183707
Ford Bronco Spacer on hub? 20221022_183427
Ford Bronco Spacer on hub? 20221022_183434
GI_Jo_Nathan
Jonathan
Was tsyje bore size of your new wheels? Should be on the inside. Bronco is 93.1mm.
GorillaGrapplr
Tim
Wheeling WV
These are the rims I got
Ford Bronco Spacer on hub? Screenshot_20221022-193249_Chrom
GI_Jo_Nathan
Jonathan
They really don't look like 108. I feel like they might have given you the wrong size. I would measure them.
AK SNO RIDER
Ty
Alaska
Looks like Trail Built either listed the wrong bore size or sent you the wrong wheels.
Mistake is on them, hopefully they'll take care of you
GI_Jo_Nathan
Jonathan
Yah looks like it. OP I would measure or at least check the size one the back of the wheel.
GorillaGrapplr
Tim
Wheeling WV
They are about 1/2 inch smaller diameter than the Bronco. Did I read correctly that these were supposed to be a 108 bore?
GI_Jo_Nathan
Jonathan
That's what the specs you posted say. Looks like they sent the wrong wheels.
GorillaGrapplr
Tim
Wheeling WV
Sorry I'm being dense little frustrated. So reading specs they should fit?
GI_Jo_Nathan
Jonathan
GorillaGrapplr
Tim
Wheeling WV
So after further investigation it looks like the bronco rim has a second recess that the new rim does not. The bore size on new rim is bigger but not wide enough to clear the notches. What options might I have now?
Ford Bronco Spacer on hub? 20221023_085525
Ford Bronco Spacer on hub? 20221023_102858
Jazer
Jessica
2.7 OBX
That is definitely not the 108mm bore they had listed, so I would contact them right away. They have it listed incorrectly or sent the wrong ones by mistake. Either way they need to rectify the situation.
GorillaGrapplr
Tim
Wheeling WV
Just measured with micrometer it came out to 77.78mm
GI_Jo_Nathan
Jonathan
GorillaGrapplr
Tim
Wheeling WV
If they fight me and wont fix the situation(Hopefully they wont) What other options do i have? Would a wheel spacer work?
