Sound system upgrade
Dbraptor
Damian
San Fernando Valley, CA
96 Cobra,Ranger,fj62. waiting on Bronco n Raptor R
I’m looking at the easiest way to upgrade speakers. I see some people have added those very small kicker amps. Has anyone done it on the Braptor? Also anyone change out the subwoofer yet? I gotta use the stock box or something similar since I don’t have any space in cargo area.
Ford Bronco Sound system upgrade IMG_5139
TheLawnDart
Austin
Las Cruces
FJ Cruiser, Subaru Forrester, Hyundai Palisade
I know next to nothing when it comes to upgrading speakers, but I know that the bronco needs some better ones! Following to see why solutions people have come up with.
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
"Search", function works great.
Dbraptor
Dbraptor
Damian
HPRBD60560
Jude
Yorkville
2022 Bronco Black Diamond
I’ve seen those. But not sure if they will fit in the Braptor the rear cross bar.
Ohhh.... you're right, I think they state not compatible with Brappy and 2 Drs. Sorry!
HPRBD60560
Jude
Yorkville
Our admin has these, not sure if they'll fit the Brap though either.
JL Audio M6-650VEX-Mb-S-GmTi
jdbabb4247
Wernersville, PA
2022 Ford Bronco OBX
I upgraded 4" speakers with Pioneer, and an added Infinity subwoofer from Crutchfield, sound is awesome!
Johnny Mo
Westchester County, NY
teachu2shoot.com
I'm leaning towards some sort of wake tower speakers if I am not happy with my sound - seems more and more likely that's gonna be the case. Not even sure if I can get them squeezed in but if I need a custom bracket made I've got a few resources that can help.
RagnarKon
Ford Bronco, Escape, Focus
FYI the sound system is exactly the same between the Raptor and the normal Bronco.
If you have the High package, you have the same 7-speaker (or 6-speaker with sub delete) that comes in the standard Bronco. And if you have the Lux package you have the same B&O system that comes in other Lux packaged Broncos. Nothing special about the Raptor... so any of the threads you see out there are applicable for the Raptor as well.
If all you are looking to do is swap some speakers around, that can be done fairly easily. If you are looking to go beyond that and install amplifiers and whatnot... that is MUCH easier to do with the High package than it is with the Lux package. The Lux package has a Digital Signal Processor, and working around that is simply more complicated and costly.
Dbraptor
Dbraptor
Damian
Thanks for the info. I just want better speakers and sub. So if I do those small kicker amps I should be good.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
My Braptor standard 7 speaker audio build (about $1500 total):
4” Speakers in front dash and rear pods:
  • Audiofrog GS42: Link
  • Bronco 4" Speaker Speaker Swap Wiring Set - with 300Hz Bass Blockers (bass blockers in front): Link
  • Design Engineering 050310 Boom Mat Speaker Baffles, 4" Round: Link
6.5” Kick speakers:
  • JL Audio C2650 woofer and crossovers only in kick panels: Link
  • Metra Electronics 72-5602 4-Way Speaker Harness Connector: get with Crutchfiled speaker order (Link) or on Amazon: Link
  • Metra 82-5605 Speaker Mounting Brackets: get with Crutchfiled speaker order (Link) or on Amazon: Link
  • Design Engineering 050330 Boom Mat Speaker Baffles, 6.5" Round: Link
Amp (for six speakers):
  • Kicker 47Key200.4 mounted under steering wheel: Link
  • KIT 11-1 KICKER KEY 180/200,4 Harness and KICKER KEY 200.4 POWER ADAPTER PLUG: Link
I haven't messed with the sub yet.
Note: my objective was the crossovers built into the Audiofrogs, and the crossover for the kick woofer.
margareedaville
'22 Wildtrak
Teejay3726
TJ
Houston, TX
2021 Badlands & 2022 Bronco Raptor
MTI makes a raptor specific rear speaker pod. I swapped those out and put Focal 6.5s in them, did the same with the kick panels, and then put 4" FOCALs in the dash.
I am in the midst of changing out the factory sub with an 8" kicker they make for small enclosures, and then add a kicker 500.1 key amp.
