Solid Front Axle Conversion?
Broncode
A Galaxy Far Far Away
1972 FJ40
What are your guys thoughts on a solid front axle swap? Will this be possible with the chassis layout?
JimmyDean
Louisiana
82 Bronco, 513 ci; 71 mach 1, 351C; 06 F-250, 6.0; 56 800, 172c.i. gas
yes, it will be possible.
kodiakisland
Arkansas
Possible? Sure. Feasible? Likely not. Better plan on burning through plenty of cash.
Someone will do it I'm sure.
JimmyDean
Louisiana
Anything is possible with enough $$$$. Will it be practical to accomplish another question and without vehicles in people's hands it's too early to tell.... Unless some drawings get leaked...
it should be fairly feasible. just use the troller axle. well, wait a year or two until it is on the exact same frame.
realistically, SAS are easy as crap. it is getting around the software that is a PITA if you want to do things like keep anti lock brakes.
Fordboi
Cameron
Murica
1966 Ford Ranchero
yeah i'd do it on a cheap-a$$ ranger first.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
Anything is possible with enough time and money but the electric rack and pinion steering will make a SAS more challenging.
rgwinn
Rod
Salem, OR
2001 Harley Road King
The other reason ford went with the IFS is for lane departure and automatic braking. Mechanically you could probably do a solid axel, but you would abandon some of the technology.
Felix808
SRV CA
Casey Currie from Currie Enterprises is already planning axle swaps on the new Bronco's
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Might make full hydraulic steering essential from the get go!
BR0NCO
Randy
Mass
Jeep Audi
Depends on frame and engine clearance. You can probably do it but may need 8-10” lift to clear everything
