Software update February 14-15, 2025
Dreamer
Kevin
Connecticut
Ford Mustang GT convertible
When I went to shut off my 2024 Badlands this evening the display told me I had an update and needed to select a time for the update.
I had my Bronco set to update daily at 1am so I was a little confused. When I checked the Bronco I saw that the software update scheduling was set to off.
now when I looked at the ford pass app I see the note on the screen shot attached.
anyone else have this. Any ideas what the updates are?
thanks.
Ford Bronco Software update February 14-15, 2025 IMG_9975
Dreamer
Dreamer
Kevin
Connecticut
Thanks. I’ll provide an update tomorrow as it’s supposed to update tonight at 1 AM local time.
Ducati1098
No problem. Also, don’t expect it to really tell you what the update even did other than some generic message. Ford doesn’t really release change logs or specifics about what an update changed.
Langwilliams
Langley
Cleveland Ohio
2023 Bronco big bend, 2014 Harley Street Glide
I got that message too. It said 1 am Mon thru Thur on mine. I'd rather it just update tonight. I saw the alert in the app too but I couldn't get it to do the update from there.
3People1Body
Christopher
West Virginia
Wildtrak, F150 and Taurus.
Curious, I haven't had an update since turning off data. I still have the Rocks to Bronco animation... If I turn on the data to get the update, does it download my driving data? I just don't like being the "product", when I purchased the vehicle.
Ducati1098
Let me know if it brings back my rolling rocks start up screen and I might consider it.
Even the very latest update still doesn’t have the rolling rocks. I think it’s probably gone for good.
Combustion_King
Derek
MA
Yes
Na these updates are for modules to help better the bronco. the window one was huge when it was for the auto up/down. They're no taking you driving data, and you can choose to have a lot of restricted in the app, but then you loose features.
i am a huge fan of not being tracked for driving speed/hard braking etc. those updates are not that stuff.
arwhite
Allen
New Braunfels, Texas
2019 Ford F150, 2024 Ford Explorer, 2024 Ford Bronco
I turned off auto updates within days of buying my Bronco. Will it let me know when updates are available? I check every now and then in the vehicle, but so far it just shows no updates available. I’m not having any issues so not too concerned about it. Just curious.
TheKim
Kim
Even the very latest update still doesn’t have the rolling rocks. I think it’s probably fine for good.
Huh. That's kinda sad.
I've still got it with all my updates installed.
I did however manually select it in Forscan when I was messing with it years ago. I wonder if that setting change helps.
I've still got them on start up and shut down, on both screens.
CarGuy
New Jersey
2023 Ford Bronco
As you create this message, you are the product.
I will say, the first thing I notice when I get in the Bronco is the rolling rocks animation. Not because it's a stunning piece of cinematography, but because it studders and stops and runs all janky. Once in a blue moon it will play smoothly, but most times it's like watching a three legged dog climb the stairs.
That said, I would miss it if it were gone.
Ducati1098
Yeah I don’t understand why some still have it and some don’t.
I had it up until yesterday. I was a bunch of updates behind, so I just did them all at work manually. And now the rolling rocks are gone.
it doesn’t bother me at all, just interesting.
I did quickly check forscan out of curiosity, but my splash screen already had Bronco selected. Changing it to a different one, then back to Bronco still didn’t revive the rolling rocks 🤷‍♂️
I would guess your APIM is not at the latest software level if you still have the rolling rocks.
