Soft Top Squeak
toybox06
Oklahoma
2022 Bronco, 2015 Mustang
My soft top squeaks when driving I’ve isolated it down to the plastic where the hinge rests. I can see some wear in the plastic here and this will likely be a fire replacement part needed I would suggest someone start coming up with a replacement solution, this rivet will have to be drilled out and replaced with a machined bolt setup along with a new plastic guide. Mine is still under warranty but fading fast should I take it to the dealer?
Ford Bronco Soft Top Squeak imag
toybox06
toybox06
Oklahoma
*future* not fire
I'm trying to figure out what you are talking about here - there's a lot of rivets even in just that photo, and I don't see anything that looks like it's wearing abnormally. And the tops in general are known to squeak and rattle all over the damn place.
I'd try just spraying it with some silicone lube and see if that helps at all. Once you start swapping stuff out on these they often are never quite the same. I spray all my seals and little joints down every time I wash it and it does help a good bit. Doesn't eliminate all the squeaks and rattles, but does cut down on it.
That said, if you want warranty support for it - you ~might~ get it depending on how your dealer is feeling that day.
Danielsand
Daniel
Idaho
'21 OBX SAS
*future* not fire
Maybe. Maybe not. If the guy wired his ditch lights wrong, maybe there will be an insurance claim, hence......"fire replacement".
Cormeister
South Carolina
XC90
Mine will squeak around that same location as well. I started using the Velcro straps tightly so the top doesn’t move, no more squeak. I also take the extra minute or so and fish the straps through the metal arms from inside the tailgate, and avoid the straps from coming in contact with the rubber seals which could possibly cause damage to them.
Danielsand
Daniel
Idaho
'21 OBX SAS
I have no idea if mine squeaks. Tinnitus gets a lot of bad rap, but it's not always bad (like when the wife starts bitching).
CV428
2023 Bronco OBX, 1969 Mustang Mach 1 428CJ
Bingo. I use 3M RV Seal Conditioner on all soft top seals and door seals, and then silicone spray lubricant on all joints. My soft top used to squeak like an old wheelbarrow, now it's silent.
NC_Oak
2024 4 door 2.3 sasq
straps? are those the things in the glove box I've never used?
There is a crude joke to be made here but I’ll let it pass
Danielsand
Daniel
Idaho
'21 OBX SAS
You are no fun! Crude jokes are what some of us are here for (some of us are not able to offer any other meaningful info to most of the threads!).
Cormeister
South Carolina
XC90
Probably. I never used them up until recently when it started to squeak like you described. Tried them out and squeak is gone, plus if I go over a large enough bump I suppose I don't need to worry about the top jumping around.
Not sure if these photos help, just trying to show how I ran the straps to secure the top and avoid pressing down on the weather stripping facing the outside.
Ford Bronco Soft Top Squeak IMG_3121
Ford Bronco Soft Top Squeak IMG_3120
adam1991
VW GTI (2)
I don't think my straps are that long...
Danielsand
Daniel
Idaho
'21 OBX SAS
It's your own fault. Short Bronco (for short people and short distances) comes with short straps also.
NC_Oak
ahhh I see. Whenever I wheel with the top down, I throw a big cable tie in that general area on the driver side to stop the noises.
