Soft top problem
56huck
Tim
State of Jefferson
Rubicon
When I open the rear hatch on my soft top, and put the kickstand down, the top comes slightly undone at the passenger C pillar. Enough so that when you get on the freeway the wind catches the corner of the top and totally undoes the connection at the C pillar and the top flaps in the wind
I have to essentially remove the side window and reinstall to get the C pillar hook to go back in
Has anyone else had this happen? It seems to happen more often when it’s cold (50-60) and the top isn’t as flexible
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello, Tim! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this soft top concern. Thanks!
56huck
Tim
State of Jefferson
Rubicon
Thank you so much!
I PM’d you the info
‘21OBX
90Bronco19
2022 bronco outer banks
hmm i use the back lift option a lot and haven’t noticed this. Is it the top or window that’s coming loose? There are latches right above the c pillar that are supposed to latch when going from full down(position 2) to just the front folded back ( position 1). Double check that they are actually latched. My passenger side doesn’t like to latch on its own. I gently lift up when moving the top to make sure after I noticed what was going on. I usually have to lift and bring the top down firmly to get the passenger side to latch. Also check to make sure your tension cables are connected in the front upper corner of the rear plastic window. I’ve had them come out of place too.
56huck
Tim
State of Jefferson
Rubicon
The window panel (not the window itself) vertical C pillar clip comes undone when opening the back of the soft top. The top itself is latched above the C pilar to the roll bar. This isn’t an issue.
the side window panel is too tight to reattach at the C pillar. You have to undo all the clips at the top of the window panel, then undo the window panel at the rear, the reattach by starting with the C pillar clip and moving rear wards. It’s a pia
tlianza
Tom
Marin County, CA
lianza.org
2022 LUX/2.7/A51/OBX
On the other side (not pictured) my rear window pops out of the clip right around this point. On this side you can see it's close but happens to hold. Is this the same problem you're referring to? If so I might be due a trip to the dealer as well.
Ford Bronco Soft top problem PXL_20220420_231924435
56huck
Tim
State of Jefferson
Rubicon
That’s it, exactly
I have an appt next week at my dealer. I was wondering if this is a common issue and what the fox was
Bronco23
Grabbed a shot of the other side where it does pop out. Definitely doesn't seem right.
@Ford Motor Company - should I PM you as well?
When you install your side windows, which side do you clip in first, front or rear? I have noticed on mine I need to clip the side closest to the door in first, then pull on it and clip it in to the back side until I hear it pop into place and I have not had this issue.
flip
Phil
IN
www.ruxerparts.com
Fords
What does it look like when closed and latched? Wondering if the cable is popping it out at the top.
tlianza
Tom
Marin County, CA
lianza.org
I always put in the door-side first. I think that's your only real option because of how the channels work at the bottom. When I velcro in the windows there's really no winning. It seems like. It either pops out or the Velcro opens up. I don't know what "right" looks like. The flap (folded down in the picture below) could go behind or atop the wire, and neither one produces a good result. Both seem sloppy and misshapen.
Ford Bronco Soft top problem PXL_20220421_230750192
coadr
Coady
Denver, CO
2022 Ford Bronco Badlands
I've always tucked the corner underneath that wire and haven't had any issues, I'd recommend trying that. There's also a thread on here of adjusting the top to fit better, maybe worth looking at?
Oday
Earth
Mine does The exact same thing it’s very annoying and it’s causing me to never lift the back. Crappy design for sure. So your saying my dealer will fix this under warranty ?
