Soft top problem
56huck
Tim
State of Jefferson
Rubicon
The dealer will look at it under warranty. If I did something wrong installing it, it might not be covered under warranty. Ford chimed in on this thread and said they would work with my dealership to help resolve the issue, which really impressed me.
I installed the side windows starting at the front, per the Ford and Bronco Nation videos. The top appears to be correctly installed
I’ll see if I can find the thread on how to make the top fit better
tlianza
Tom
Marin County, CA
lianza.org
2022 LUX/2.7/A51/OBX
Double check that they are actually latched. My passenger side doesn’t like to latch on its own. I gently lift up when moving the top to make sure after I noticed what was going on. I usually have to lift and bring the top down firmly to get the passenger side to latch.
Yes, I have this problem too. It takes quite a bit of pulling to get them to latch on both sides (driver side is worse for me) but they do latch.
Also check to make sure your tension cables are connected in the front upper corner of the rear plastic window. I’ve had them come out of place too.
I'd love a photo of this. I can't quite tell what it means and it could be my issue.
ā€˜21OBX
Ken
90Bronco19
2022 bronco outer banks
I've always tucked the corner underneath that wire and haven't had any issues, I'd recommend trying that. There's also a thread on here of adjusting the top to fit better, maybe worth looking at?
I believe the instructions say to tuck behind the wire maybe this is why mine don’t do this. šŸ¤·ā€ā™‚ļø
56huck
Tim
State of Jefferson
Rubicon
I couldn’t find the thread to make the top fit better. Do you know what it’s titled?
56huck
Tim
State of Jefferson
Rubicon
Update:
I took it to the dealer last week. They ordered a replacement side panel including the window and front plastic clip that hooks the C pillar. It came in today and I have an appointment for them to install next week under warranty.
A Ford personal service rep contacted me. I’m surprised and impressed that Ford is following up on this. Pretty cool.
tlianza
Tom
Marin County, CA
lianza.org
I took mine for service on a different roof issue ( https://www.bronco6g.com/forum/threads/soft-top-latch-issue.30901/ ) and I showed them this issue while I was there
They basically said that it didn't look wrong and maybe it will get better as the car breaks in and the roof gets more pliable. In my case, even though the windows pop off the pillar when the kickstand is up, they also slide back into place when the kickstand is down, so the issue isn't particularly serious. Just seems cheap and weird.
KnoxGnater
Nat
Knoxville, TN
1934 Ford Roadster Pickup, Bronco Badlands
That's total BS from your dealer. WTF needs to "wear in"? They are probably too short handed to care about your issue. Any other dealer options close by? You're selling dealer does not have to the one that fixes it.
I've had mine open hundreds of times and never had either panel pop out of the channel.
Check the manual about removing the soft top, there are some diagrams that show alignment pins, etc that may be helpful. Its probably a minor misalignment issue, QC from the factory is pretty hit and miss on these.
JohnnyBronco
Pennsylania
X4
Hah! If anything, over time, your visqueen windows will turn yellow and brittle, not more pliable.
And if you know what visqueen is without looking it up you are, as I, older than dirt, lol
56huck
Tim
State of Jefferson
Rubicon
Update: The dealer replaced the side panel with the window. The first time I lifted the rear and put the kickstand down, it popped out near the top on the C Pilar, but went back in place when I closed the rear. It didn’t pop out at all on subsequent openings
