Soft top problem - drumming/thumping when windows down
DCblue
'22 OBX
My soft top (just the top cover) was recently replaced under warranty on my ‘22 4 door because it was coming apart at the rear passenger corner.
Now whenever I drive with the windows down a small portion of the top cover slaps up and down in the location/gap identified by the arrow in the pic below. It is definitely worse with only one window down and you exacerbate buffeting. Is this normal for the updated top? My prior top cover was the old design and didn’t do this.
You can stick your hand in the gap or place something like a towel in the space and it stops. I’m taking it in soon for a different issue and not sure if I should complain about this - dealer was great about replacing the top.
Is this just normal behavior for the “2.0” soft top?
Ford Bronco Soft top problem - drumming/thumping when windows down IMG_0040
NC_Oak
2024 4 door 2.3 sasq
I have a 2024 and it does not flap like you describe.
Headsong
My 22 does that exactly. Not all the time....but from time to time. I'm tempted to spray some Gorilla Glue in there....
helifino16
Ron
Mount Sinai, NY (Long Island)
Isn't 'thumping' a common issue with almost every car?
Get yourself some foam and stuff it up there - problem solved.
DCblue
DCblue
'22 OBX
Sure, if you have just one window open you get some buffeting in most cars. However, this happens with two front windows open and the area noted slaps up and down.
