Soft Top Install
trader979
New Jersey
bronco
Hello All,
Just purchased a 2023 take off 4 door soft top with all the hardware. My question has to do with aligning the brackets behind the panels as if seems there is a lot of adjustment play and once the top is on it needs to be removed to adjust further. Any tips as far as starting location and/or making the process easier? Thanks.
Ford Bronco Soft Top Install IMG_7045
ironmann
Elmhurst, IL
Ford Bronco
If you buy the bracket as a standalone part (M2DZ-7829452-A), it comes with a plastic alignment template that makes installation a breeze. I'm not sure if you can buy the template by itself. I think I still have it up in my attic, so I can check to see if it has a part number, but I can't get up there tonight.
Otherwise, there are some good tips in this thread by robrod802 that at least give you a good start on getting it aligned.
https://www.bronco6g.com/forum/threads/soft-top-install-instructions.94496/page-2
trader979
New Jersey
bronco
I ended up ordering a new set of brackets today just to get the alignment tools.
BroncoAJL
Al
CA
2022 Ford F-250 and 2023 Ford Bronco
I'm looking to get the alignment tool, but the Ford sites I went to says M2DZ-7829452-A
is replaced by M2DZ-7829452-B.
Do you know if that has the tool also?
Thanks
ironmann
Elmhurst, IL
Ford Bronco
Part M2DZ-7829452-B comes with the alignment tool, that's the one I ordered. I just realized I listed part M2DZ-7829452-A in my first comment, I must have pulled that from an old spreadsheet I had. I'm not sure if -A comes with the template, but -B did when I ordered it.
BroncoAJL
Al
CA
Thanks Ironmann.
tock13
Tony
WA State
Mazda, 66 Honda CT90, ‘94 Toyota Xtra cab
Agree with @ironmanm, I ordered same “B” P/N and got it last Friday, mine too came with plastic alignment guides.
trader979
New Jersey
bronco
Anyone doing a top swap. Get the alignment tool. Makes the process rear brackets install easy peasy. Installed rear brackets with tool, roll bar brackets all the way rear, and tailgate brackets all the way up, everything works perfectly. No need for any further adjustment.
tock13
Tony
WA State
How was lifting the actual soft top into place before bolting it up? Seems light enough but my helper is 5’0”. Might need set up something to stand on.
How did you deal with spare? Did you just unmount the tire?
trader979
New Jersey
bronco
It’s heavy and cumbersome. Worse than the hardtop. I’m 6’2” and I went over the spare with the tailgate open. My helper was 5’8”. Sets right down on the alignement pins.
Area51BS
Ron
Badlands non SAS 4dr 2.3
As an fyi the lower left and right rails along with tailgate rail all meet at a corner pieces. Loosening the bolts allow adjustment of the extruded rails closer or further from the corner to help get lower corners of D pillars and side windows right. But mess with that last if at all.
Maryland
2025 Ford Bronco
Sorry to resurrect this old thread, but when I look up this part number, I can’t tell if it comes with one bracket or two. I saw another thread where they ordered two sets, but each set had two in them.
ironmann
Elmhurst, IL
Ford Bronco
They come in pairs. One part number gives you both brackets and the alignment tools.
