Single Compressor Under Hood Mounting Solution
PleaseDontRoll
Reno, NV
2018 Subaru Crosstrek
I was looking for a cheap air compressor with a 100% duty cycle and not particularly concerned about how long a fillup would take and got a great deal on a Viair 450C compressor. I didnt want to spend $250+ on a bracket for a $180 (to me) compressor and it took some figuring to decide on how I wanted to mount it in the engine bay and ended up with this.
Bracket was purchased from here: https://www.youngstowncycleandspeed.com/product/viair-compressor-side-mount/ for only $30.
It comes flat and is a 'bend it yourself design'. I opted to use it in a different configuration bending only the two tabs top and leaving the sides flat.
I then drilled some holes through the sheet metal lip at the back of the hood and mounted with 1/4" x 3/4" machine screws and a few washers as spacers to give it a bit extra clearance and ensure nothing is rubbing. Clearance is tight as you can see in the pictures but no rubbing so far. I will bolting a small bar onto the back of the bracket that will push out against the firewall to ensure that it does not vibrate/sag too much when desert running at high speeds.
Black wire grounded to the vehicle, red wire to a 40 amp relay that I wired to aux switch 6 (wanted to save Aux 1/2 for other items). Control is exclusively by switch, no pressure cutoff, no tank, and as of now I only run a MORRflate setup off of it to air up and down. Still need to route the output line to somewhere near the rear bumper.
The location does get hot but even after wheeling for 7-8 hours in the desert it still ran without stopping for filling my 35" tires from 18 PSI to 40 PSI in about 15 minutes.
Just thought I'd throw it out there in case anyone else is looking for cheaper mounting solutions.
Ford Bronco Single Compressor Under Hood Mounting Solution IMG-3745
Ford Bronco Single Compressor Under Hood Mounting Solution IMG-3746
Ford Bronco Single Compressor Under Hood Mounting Solution IMG-3748
Ford Bronco Single Compressor Under Hood Mounting Solution IMG-3747
Ford Bronco Single Compressor Under Hood Mounting Solution IMG-3749
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
That’s cool. Thanks for sharing. I really like that position in the bay. I’ve been running the Toolbox ARB - but, was considering mounting it to save space inside the vehicle.
Roger123
Roger
VA Beach, VA
Looks good, nice job.
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
How long does it take to fill all 4 tires?
PleaseDontRoll
PleaseDontRoll
Reno, NV
About 15 minutes from 18-39 PSI w/ the 35” SAS tires.
Rick Astley
Up Doug's ass
d
That's a great compressor. Minimum size from ViAir that can fill a 35" tire and is very robust.
It does make me wonder about the trademarking and IP of that compressor bracket.... I seem to recall that there was a vendor on here threatening lawsuits if people made a bracket to fit an air compressor..... But what if ViAir was first with a compressor bracket????? :unsure:
billynup
Washington
22 base squatch
Thanks for the tip, I was debating which compressor I wanted to go with and found a good deal on a 450 as well. now to order than mount!
Geo
Geo
Ford Mustang
What vehicle is this mounted on?
PleaseDontRoll
PleaseDontRoll
Reno, NV
