Sidewall question
Old Codger
Durango CO area
JLU Rubicon, Wildtrak
I am looking at 2 similar tires from the same manufacturer. One is a 315/70 - 17 load range D and the other is a 35 x 12.50 x 17 load range E2. Both tires have 2 ply sidewalls. Will the sidewalls on the E2 tires be tougher/less likely to be torn by rocks than the D rated tires? I assume the higher load capacity will have thicker plies in the sidewalls to carry the higher load, which may make them more tear resistant. But, I also know enough about engineering and materials to question that assumption. Any thoughts one way or the other?
I understand both are overkill in terms of load capacity on a Bronco. I am not asking about assumed ride quality differences.
thanks
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
I'm not a tireologist but are you sure the 35 inch E rated tire is only 2 ply?
That doesn't sound right to me.
Old Codger
Old Codger
Durango CO area
@DriveAllNight, I agree but that's what the manufacturer's description for this tire name says (not tied to this specific size).
Well E vs D is a load rating so it doesn’t directly correlate to puncture/tear resistance - but you can infer if a tire is rated for higher pressure/load it had to do something to strengthen the side wall to support that.
Commonly that’s more plies - it it can also be something like Kevlar or thicker material.
Doesn’t provide any guarantee mind you - because again, it’s a load rating. But I would bet a sidewall on an E would hold up better to abuse than a D (even if it’s just marginally)
An E rating would also be more prone to slipping a bead at lower tire pressure than D rating due to (probably) stiffer and/or thicker sidewalls, and it will tend to weigh more due to the additional material.
So pros and cons
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
Way old background info: they’re actually called “pneumatic tires” because the air holds the load. The sidewalls (carcass) don’t hold up the weight - they hold the air pressure inside and that air holds up the weight.
This is the 21st century; tire engineer have figured out how to contain high pneumatic pressures without the necessity of utilizing umpteen layers of material.
Old Codger
Old Codger
Durango CO area
Thanks @SuperDave150 for politely reminding me of the obvious thing I knew at some level but had not thought through. Makes the decision much easier. No value adder for the E rated tire in this case, only weight penalty.
dgorsett
colorado
F250, Mustang, Explorer
Well, you said it...."weight penalty". Meaning, the E has more stuff. It's the same height and width, so the more stuff must be thickness. More thickness=puncture resistace.
Canyon Coolers
Jason
Flagstaff
canyoncoolers.com
73 Bronco, Dodge 2500, Sprinter Van
I got to sit in on a few hours of Kenda's tire school recently. Ply count is deceptive since they can be of any thickness and any material. I would not over think it, but instead source a brand you trust in the right application and load rating for your vehicle since it is designed to ride a certain way and have a certain footprint under a certain load.
