Side Mirrors Wish List
Last Ride Bronco
southern USA
Nissan pup
I would really love to have my side mirrors dim at night like the rear view mirror does. Is there such a thing? I get tired of being assaulted by bright lights from cars behind me at night. Has anyone in 6g land found a way to address this other than readjusting your seating position?
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
I’ve never seen that.
Friendly suggestion: Adjust the mirror out so when sitting in your normal position you’re not getting blazed. SOP.
I don’t have my bronco yet so my comment above is merely based on my age not hands on with said vehicle. But….I can only assume the side mirrors are “normal”.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
My ‘14 Subaru FXT had dimming mirrors. Loved them!
Unfortunately the Auto dimmers aren't a bronco thing… but your aren’t completely SOL.
Check out @Suma Performance Mirrors!
After having Base/Non-BLIS mirrors with the convex blind spot corner mirror, I found myself missing the FOV it offered compared to the BLIS mirrors.
I swapped to the Suma BLIS+Defrost+Antiglare. They have a slightly more aggressive R value (Convexness/Radius) compared to the flat OEM Mirrors! Would buy these again. The blue takes a week to get used to, but we’ll worth it for night drives… all drives!
As far as install goes, you need a third hand to release the BLIS LED harness connector on the back of the mirror itself… re route the defrost plugs, bend/crimp the female blade connector to make it a snug fit on the Suma male blades and you are good to go. Maybe 5 minutes if you know what you are doing, 15 tops for a first timer
Ford Bronco Side Mirrors Wish List C126C865-8A56-4005-98EA-FFE03C69059F
Ford Bronco Side Mirrors Wish List FF39874B-2A7E-4EBB-935F-76E15DC167AB
Ford Bronco Side Mirrors Wish List 27536DC9-9044-4D91-AA16-5B48BC4045DD
rtazz17
Connecticut
2022 Ford bronco big bend
Idk. Been driving for 34 yrs and my mirrors are adjusted so that headlights behind me literally are not seen unless I put my head in the mirror. You stated “normal position”. If your normal position has you eyes getting blazed by headlights then you are not adjustingyour mirrors correctly. Scratching my head on this one. Not flaming you at all on this but I really dont understand. Headlights in your seated normal position should never be any kind of annoyance. I have very sensitive eyes to light especially since hitting 50 yrsold but not from mirrors. Its through windshield that bothers me at night only
PSUTE
Western Maryland
Sierra
Has not been an issue for me...
BostonSasquatch
Randy
Boston
Bronco Lux Badlands with hardtop and Sasquatch
Since this is a "wish list," I'd love to have an exterior mirror with power folding arms. Had them on my top-of-the-line Toyota Sienna. A great convenience, especially when you're parked on a narrow street.
And maybe an extendable arm for when you're trailering.
Suma Performance
Eddy
Seattle
We are running a Group Buy now LINK.
Suma Performance
Eddy
Seattle
My base doesn’t have any aux switches. Will installing the mirror with BLIS be an issue in terms of wiring?
The BLIS on SUMA is compatible with the OEM BLIS, plug and play. Your car mus have the BLIS feature. Hope this helps.
BroncoHI
Kenneth
Hawaii
2022 Ford Bronco Black Diamond
My wires came out of the BLIS harness while removing the window. I tried putting the wires back in but they don't seem to be connecting. Do you have any suggestions?
Mahalo
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Mahalo
Bend them slightly and add dielectric grease.
