side mirror replacement
gonyr
NY
I hit a branch backing out of my driveway and broke my driver's side mirror. All of the mirror functions and the cover are fine, but the pivot between the arm and head is destroyed so the mirror just flops around loosely and vibrates/shakes above 20mph. As some of you know, the replacement is insanely expensive.
My questions are, does anybody (maybe @Ducati1098) know if the internal structure of the mirror is the same between what I have with two lights and 360 camera versus one of the other models that doesn't have those functions? In other words, is it possible to purchase one of the cheaper mirrors and transfer over the electronics and wiring from my broken one? Are the mounting points for the flood and puddle lights and 360 camera present even in mirrors that don't have them?
Thanks in advance for any insights.
Ducati1098
I’m pretty sure the overall structure of the mirror is identical between all of them.
A good person to ask for a concrete answer would be @Tricky Mike because he dealt with a similar thing where he bought a lower level assembly and just swapped everything over after damaging his mirror.
gonyr
NY
That’s very promising. I hoped it might be true just because it’s cheaper/easier to only have one type of mirror frame. Thanks.
Tricky Mike
21 Bronco
It sure is. You'll need to salvage all your components and wiring to swap over.
I used the lowest optioned base mirror and fitted back up to the highest optioned.
gonyr
NY
Awesome! Exactly what I was hoping to hear. It looks like it won't be too difficult. Any tricks or tips to watch out for in swapping things over?
Tricky Mike
21 Bronco
Just make sure everything is routed and seated like originally. 10lbs of crap in a 5lb sack.
gonyr
NY
Just finished. Not too bad. Hardest part was either feeding the wires up through the elbow or figuring out that the motor needed to be removed in order to connect its wiring plug. Most frustrating part was finishing then realizing that I forgot to pull the wiring harness through the opening in the arm and the connector wouldn't fit, so I had to disconnect everything, pull all the wires back out, and start over.
BUCKIN6VA
Northern VA
www.youtube.com
'12 911 GTS, '25 Model X
Same situation - smashed into a tree offroading and broke the driver mirror.
So you just bought a "base" mirror assembly right? Then swapped in your mirror parts?
gonyr
NY
This is the one I got. All functions are working perfectly. You will need to swap over all the internal components, and also reuse your current mirror cover because the base cover won't have mounting points for the lights or camera:
https://www.ebay.com/itm/276938636180
It wasn't a big deal to move everything over. If I hadn't screwed up the routing for the wiring harness the first time through it probably would have taken about 60-90 minutes total, including the time needed to unmount and reattach the mirror assembly on the vehicle. Take pictures of where the wires go as you disassemble. You'll need to remove the motor to connect its plug.
BUCKIN6VA
Northern VA
www.youtube.com
Thanks! I just wrapped up. Took me about two hours start to finish - wasted a lot of time routing/double-checking wires because (of course) I didn't take enough pictures along the way.
I bought a similar one to what you recommended and even though it didn't have the camera cutout, I simply reused my original mirror cover (undamaged) and harness. In my case, I was replacing because it had broken at the elbow (as same you) and this has me back up and running without duct tape on an expensive car.
deneech
Dennis
Long Island, NU
I’m in a similar situation but instead of me hitting a branch, my 18 year old hit an open car door! I’m ready to pull the trigger on a lower end mirror and transfer everything over…but two questions: for BLIS, will I need a new mirror with the indicator built in? Also, this is my 369 camera view…do I need to replace or just recalibrate (and can I do that myself)? Thank you all!
Ford Bronco side mirror replacement IMG_3863
gonyr
NY
When I did this, all of my mirror functions worked fine, it was just the arm that was broken. That arm and the mirror frame were the only pieces I used from the cheaper replacement. The glass, all of the internal sensors and wiring, and the cover, all came from my original broken mirror. So if your original BLIS is still working, then you would be using it in the replacement. The arm and mirror frame are the same across all trims. The cover isn't, but luckily mine wasn't broken.
Your 360 view is obviously out of alignment, but that could simply be from getting broken. If it was me, I would do the mirror replacement first and see if the camera just takes care of itself. I'm pretty sure it only mounts in one possible orientation.
deneech
Dennis
Long Island, NU
Really helpful, thanks for the response. Maybe a stupid question: my BLIS works even thought the mirror shattered…can I get a new mirror glass without BLIS and still see the BLIS indicator through it, or do I need compatible a BLIS mirror?
Ducati1098
It probably works because the BLIS warning light on the mirror is still okay.
If you have BLIS, you have to get a BLIS mirror, otherwise there will be a fault message on the cluster at all times because the light in the mirror is gone.
