Side Camera Blank Spot?
Scoop
Gary
Cuchara, Colorado
2026 Stroppe Edition, '74, '76, & '78 Broncos
Has anyone had this issue? I'm assuming it's a bad camera that will need to be replaced (hopefully) under warranty by Ford?
Ford Bronco Side Camera Blank Spot? IMG_3896
Ford Bronco Side Camera Blank Spot? IMG_3897
AK SNO RIDER
Ty
Alaska
It's also not lined up right...sounds silly but have you made sure your mirror is seated in the right spot and not angled a little forward or back?
Scoop
Scoop
Gary
Cuchara, Colorado
Mirror is in the correct position BUT looking at it more closely, it looks like the camera on the driver's side mirror is out of place compared to the other side. Good call! Thanks!
I'll see if I can fix that.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello, Gary! I would like to look into this camera concern on my end. Please send over a private message with your VIN and the name/location of your local Ford dealer.
gonyr
NY
I get this happening occasionally on the driver’s side, especially in cold weather. Just a big blank area. The dealer was unable to find anything wrong. My guess is it’s a slightly loose connection somewhere. It usually goes back to normal the next time I start the vehicle.
Ford Bronco Side Camera Blank Spot? IMG_1994
rugedraw
Javier
Miami, FL
2021 Ford F150 Platinum FX4 EB/2023 Bronco Sport Badlands/1991 Mustang 5.0 coupe
You can try an IPMA calibration procedure with FORScan. It will cost you next to nothing if it doesn't work.
Scoop
Scoop
Gary
Cuchara, Colorado
Problem solved!!
The plastic cover on the driver's side mirror was not seated correctly. It was very slightly out of place. The camera was in place and the cover had slightly covered the lens. I pushed cover back in place and all is well!
Ford Bronco Side Camera Blank Spot? IMG_3900
The only thing I can think of is I took it through a touchless car wash which had a pretty powerful spray. I noticed the issue after using this car wash a couple times.
