Should this bolt look like this?
DaddyLoafn
Maryland
24 Bronco Black Diamond 2dr 7speed
I did the first oil change over the weekend and noticed this bolt on the passenger side looks like it wasn’t tighten down. It's on the passenger side, and I believe it's for the steering rack but i could be wrong on that.
Just curious if it’s supposed to be like that?
Sorry not the best pictures
Ford Bronco Should this bolt look like this? IMG_4988
Ford Bronco Should this bolt look like this? IMG_4989
BroncoChallenger
2024 Bronco
Without being back just a bit further, that LOOKS like a lower control arm bolt. In which case it goes through a steel sleeve, which is surrounded by a rubber bushing. If it isn't loose when you put a wrench on it, then it's tight and I'd leave it alone.
Again, this is a guess because I can't tell with 100% certainty what that bolt is holding in place.
DaddyLoafn
Maryland
Here’s a better picture.
Looks like it has a bushing in it but still wanting to make sure its suppose to be like this lol
Ford Bronco Should this bolt look like this? IMG_4993
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
PWillette
Parrie
Maine
Looks like one of your FDU mounting bolts. So long as it is tight it is good.
DaddyLoafn
Maryland
Thank you. When I get home I'll put a wrench on it and see if its tight.
My transmission sometimes feels like a tractor sometimes and sometimes feels fine and I have a theory that something may be moving causing it to bind up on itself and if that's loose that would be a sign that I'm onto something lol.
But that theory is purely speculation based off limited knowledge lol
TXBronco1313
If I were you, I would be concerned if it didn't feel like a tractor lolol
DaddyLoafn
Maryland
lol. Its just weird my first transmission felt like a tractor all the time plus the other stuff it was doing and my second one has distinguishable moods. For days at a time it'll feel the same as my focus rs or speed3 did and then out of nowhere it'll feel like the 87 Kubota we had on the farm I grew up on lol
