Shocks after 25k miles - leaking or corroded
Heca10
Imperial
2022 Bronco Badlands
It seems like shocks are leaking or corroded. What do you think is this normal or definitely look into warranty?
Ford Bronco Shocks after 25k miles - leaking or corroded 1000025756
Ford Bronco Shocks after 25k miles - leaking or corroded 1000025755
Heca10
Imperial
Do you think ford will warranty the replacement?
mcinfantry
Lee
Louisiana
Badlands 2 door
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
I don't see any evidence that they are leaking, though it is hard to discern with the photo mashed up into individual quadrants. There is plenty of evidence of the paint being chipped and rust forming on the unprotected metal. Why would you think that would be a warranty item?
KillerPenz
North East
Those shocks are garbage, replaced my 1st one at 42k miles after it rusted and all the fluid leaked out. Once the others started going I replaced with different shocks.
Some of your pics do show what appears to be the fluid leaking out. I've heard some people have got warranty replacements, and some haven't. If you want to go that route contact the dealer and see if they go for it. But my advice would be to swap that garbage out for something better.
MJ12
New Mexico
Dodge Charger 392
Mine looked identical the day I drove it off the lot and haven't worsened. It's been over a year.
Heca10
Imperial
I don't know why the pictures keep uploading like that. Yes there's rust and small leak. How long does the shocks normally last. I never had a car need new ones until after 70k 100k miles. I wonder how people got it warranted
Heca10
Imperial
KillerPenz
North East
Typically they last a lot longer than 25k miles. But these (as many people have stated), were built to Ford's specs. They are cheaply made and there are countless threads on here about people having this same issue. Quite a few even had the entire reservoir pop off.
Since I have the Sasquatch package I just went with the Bilstein 6100's (no reservoir), they work with the squatch springs and I think I ended up getting them for under $1,000 off ebay. No problems since.
Ducati1098
Well rust isn’t warrantable.
And that isn’t a leak, so it wouldn’t be covered at this point.
If the reservoirs fall off like many do and you’re still under 3/36, then it would be a warrantable issue.
heavyD
Calgary, Alberta
2025 Badlands 2-Door
Down the road the reservoirs could start falling off. Once they fall out it becomes easier to warranty but I expect a lot of owners will have reservoirs falling off out of warranty once these vehicles get older. It's unfortunate but these shocks are designed extremely cheaply. I'm surprised Bilstein would even put their name on these given the quality but it's pretty clear Ford really put the screws to suppliers for these vehicles as Webasto still can't produce quality MIC tops for the price Ford wants to pay.
Bruno
Bruno
Sierras
Meh whats the big deal they are "weeping" a little fluid. Probably no effect to performance. Likely they would last another 10-20k before you feel something.
Do you know what the service life is for these? Know when they are recomended to replace?
When you do replace, just get some Bilstein 5100 shocks. Heck, you can even lift it an inch or 2 with those and stock springs!
https://offroad.bilstein.com/en-us/products/bilstein-b8-5100/
https://cart.bilsteinus.com/catalog...Level 2&category_id=1&catname=Shocks & Struts
Ford Bronco Shocks after 25k miles - leaking or corroded 1733417985323-z2
2door
AA
!!!FOR SALE!!! 2022 Bronco® The Sasquatch™ 2-door
I got the rear right shock replaced under warranty at around 15k miles. The request was approved without asking any questions.
Ford Bronco Shocks after 25k miles - leaking or corroded 1733418783180-n6
Heca10
Imperial
I have the sasquatch too. I will look into those.
