Selfsquatch a badlands down the line?
elseminoleguapo
Javier
Miami
Basesquatch
Suppose you get a non-squatch badlands 7mt. Ride on the 33s until it's new tire time then add 35s and the lift to accommodate them. You ending up ny different than a Sasquatch beyond the rims being different?
BlueBronco
DFW
You would still be lacking the 4.7 gearing
Edit. Stand corrected (x3 and counting) see below. What I meant to type is the wider fender flares
Apples
Nick
2022 Jeep JLUR, 2024 Nissan Ariya
You may need new rims too. The Wildtrak has a wider track than the Badlands and I'm relatively certain (totally guessing) it's due to a rim with a different offset. I'm hoping the upgraded Badlands rims are actually the same as the Sasquatch rims. They're both referenced as beadlock capable with a different color "beauty ring".
FWIW, I'm going this route.
Apples
Nick
Badlands MT gets the 4.7 gearing. That particular trim is only lacking rims, tires and whatever suspension is needed to fit them.
Apples
Nick
Also, selfsquatch??
Ford Bronco Selfsquatch a badlands down the line? giphy
Apples
Nick
I REALLY hope Falcon Shocks makes a set of these for the Bronco.
BeerForMyHorses
Nebraska
Ford Bronco 2-Door
Manual Badlands comes with 4.7 gearing
Edit: lol. Just noticed this has been twice covered already
Apples
Nick
I always forget about the stupid fender flares. If I end up hitting them they're just going to come off when I wheel.
elseminoleguapo
elseminoleguapo
Javier
Miami
Basesquatch
Yeah the flares should be a cheap swap if going this route. Sounds like wheel width is the only thing of much substance. And beadlock if you care about that.
Hey19
JJ
Bethlehem
If I have learned one thing on this board, it's that everything involving the Sasquatch must be turned into an X-squatch portmanteau.
*looks up “portmanteau” because knowledge.
