pandapaul
Paul
Tallahassee, FL
2021 Badlands Sasquatch
Goddamn. Those look fly as hell. Excellent work.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Here it is in it’s prime….1.6 16v, 3spd auto, 6.5 case. Fully built trail gear yotas running 37 reds. I ended up disassembling it to upgrade some things and do a full tube chassis….I’m not super far off from finishing but I got distracted by vacationing and then the new bronco so it’s been on the back burner for awhile now. New version is 2.0 3 spd auto sidekick case to samurai 6.5 case, same yota axles, ori struts and 39 reds…..as far as yours goes I would just give it some thought on what you wanna accomplish and what you would use it for and go straight to that. Once you go past 31s and samurai axles the street ability goes down drastically. Lol
The idea was to take it off the street altogether but a guy I've wheeled with suggested keeping it somewhat street legal because you can do more than a buggy. I have a 3.8 Ford V6, NP435, dual yotas, 38s on beadlocks, and elockers ready to go in addition to those yota axles.
Mdsuits
Mdsuits
05 f350, 68 bronco 89 samurai
Yeah if your going that drastic it would be easier to go full tube chassis…I don’t know where you live but I kept my buggy tagged and drove it on the street occasionally here in Colorado up till about 4 or 5 years ago…never had a issue…
Donkeygyrl
Sheri
San Francisco
Bronco on order
I have some nice sliders off a jeep that are almost a perfect fit for my 2dr i could make some mounts but im wondering if its worth the trouble.
I have other dedicated rock rigs and the bronco sure aint gonig to be one .
Intrested to see what everyone does for the mounting.
Mdsuits
Mdsuits
It’s just a matter of would you rather spend time getting under there and design and build something….or just spend money and wait on long lead times to get some…next venture has some well designed body mount sliders. I would bet the 29 spline ifs front and pinky sized tie rods would fail long before their mounts. I do have some ideas for better mounts but I’ll see if these hold up very well before I get to carried away.
Mdsuits
Mdsuits
I think that those look great, I know how much fun fab work is! Give me some welders and some metal to weld and I might build you a shopping mall somewhere!
I do wonder though, how close are you to the body of your Bronc? I would worry that should the sliders be used as intended then the weight of the vehicle might push the sliders into the actual body of your "Off Road Destroyer" putting some unsightly dents into the fine Ford body work.
I might be wrong, I can't really tell the gap distance from the pictures.
Anyways, they look good and I am glad that you had fun making them!
Ok finally got a chance to put a tape measure on it….the smallest gap between the slider and body is 1”. I know the pictures tend to make them look closer cause of the angle.
broadicustomworks
Hanging Rock, North Carolina
I'd be really interested in seeing how and where you gusseted the factory mounts.
I have a set of extra factory rock rails and a set of JL sliders to weld onto them (carbon copy of @Tricky Dick project).
I plan on doing some reinforcement on the mounts as I do it vs. taking them back off, grinding, painting, having to re-install.
I could figure it out but I may overthink and over-engineer it, as I am prone to do.
Mdsuits
Mdsuits
Dang I thought I had some farther away pictures on my phone but yes I can. Probably won’t be till tomorrow evening.
Hopefully I’m not to far away now.
Ford Bronco Self Built Bronco Sliders Using Bender & Welder 6AC8520A-26E2-4EF8-A157-C5DE5890402F
Ford Bronco Self Built Bronco Sliders Using Bender & Welder 296782D0-E8E9-4DF0-B62D-416AF09A9B13
Ford Bronco Self Built Bronco Sliders Using Bender & Welder EA41BA66-C30A-45EF-91DE-0FD09DB884E4
Ford Bronco Self Built Bronco Sliders Using Bender & Welder 54E50A2E-3CB6-4E7E-B158-252C8A7E28D6
Ford Bronco Self Built Bronco Sliders Using Bender & Welder D934BADE-8B18-466F-ABD0-66B22F9CA2AD
Ford Bronco Self Built Bronco Sliders Using Bender & Welder 0B7A9766-4D30-43E5-896C-9CF9046241AE
Ford Bronco Self Built Bronco Sliders Using Bender & Welder EE600813-82EF-473F-B433-E99CE0655A67
Mdsuits
Mdsuits
Just in the main unsupported bend I added one on each side. If I had it to do again I would go bigger but I originally planned to put something across to catch the bolt hole underneath with a extra bolt so I needed to keep it accessible….I did change out a couple of the pinch weld bolts to slightly larger grade 8 hardware as well. I’m not sure it will help a whole lot but it’s got to be better than fords lil Chinese studs.
Ford Bronco Self Built Bronco Sliders Using Bender & Welder 4C44939E-B50B-4500-9486-09A6FAB1806B
Ford Bronco Self Built Bronco Sliders Using Bender & Welder 68BCF57B-5DA2-48B7-939F-FFAFB1C6EF86
broadicustomworks
10-4. Thanks, bud!
Donkeygyrl
Sheri
San Francisco
Bronco on order
Wow so the ford rails use the pinch weld ,thats what your kinda out to protect ,you did beautiful work though 👍
Mdsuits
Mdsuits
Well the ford brackets got me thru my lil bit of time up at super celebration…..I did manage to bend one a bit with a hard hit to the front outside corner of the slider on iron chest. This weekend I went back and designed and built my own brackets…
Ford Bronco Self Built Bronco Sliders Using Bender & Welder 77424543-B72F-4F08-B570-1B633648177C
Ford Bronco Self Built Bronco Sliders Using Bender & Welder 874315FE-6752-4A8D-B042-3DA3429781C5
