DIY self made bumpers?
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
Knowing my own welding skills, I’ll never stand anywhere close to a homemade recovery point of any kind while in use.
Alan22
Alan22
Alan
TheMightyMO
2021 Bronco, 2015 Mustang GT, 2018 Wrangler Sport
Most Tow points on new vehicles aren't welded, they're bolted to a torque spec. Even the ones on the modular bumper are bolt on.
Little Foot
Buffalo
non-SAS Badlands
Years ago, my buddy make his bumper for his Grand Cherokee. He took thick cardboard to build his mock-up and when he was satisfied with what he had designed, he disassembled the cardboard, all held together with tape, and used it all as templates for cutting, grinding and welding.
It takes time, but goes back to the saying, measure twice, cut once. With that, he used spot welds putting it together, did his test fit before doing all the final welds.
Even if you cannot weld yourself, you can do all the cardboard mock-up and then take it down to a machine shop and pay them to build it for you. More likely than not, you will still come out ahead with a custom bumper designed by you for your needs, wants and vision for cheaper than ADD or any of these other companies. You can even incorporate a light weight aluminum skid plate. Just remember aluminum and steel do not mix, so you will need some kind of composite spacer or depression of some sort 😁
wrbix
VA and FL
…of that I am aware.
See a lot of modded LRs with welded on recovery points.
Alan22
Alan22
Alan
TheMightyMO
I like you wouldn't trust that at all, but on the counter side should we trust bolts?
wrbix
VA and FL
I suspect OEM designs have the proper engineering and fastener grades behind them.
