- Dave
- Aug 25, 2020
- 42
- 4,109
- 16,690
- Hanging Rock, North Carolina
- 19 Z71, 06 VTX1300, 94 Cobra, 21 BL Bronco 4dr.
- Badlands
With all due respect (and I DO respect your posts, knowledge, and input) I never said they were useless, verbatim.I 1000% disagree with your conclusion that the GOAT Modes are useless. BAD ADVICE.
Step 1 is knowing what the GOAT modes actually do...
GOAT Modes don't just activate 4wd, lockers, and disconnect, they also control throttle response, shift points, and traction control. This is a very big deal if you're in sand, it gives you much more control vs just 4wd and lockers.
My advice, set the GOAT Mode that most fits your situation then make adjustment accordingly. As an example, if I'm on the trails (moderate to hard stuff) I go into Rock Crawl Mode then turn the lockers off and only turn them back on when I need them.
For the OP's question. My advice is to go through your Owner's Manual along with the Quick Reverence Guide and get familiar with what how Ford suggests you use the off-road features. From there, yes, go out and test but be careful to understand the correct situations (speeds for drive modes, when to NOT use 4wd,...). But ya, I would have probably only used 4H in that situation, maybe just regular 2H.
Here is a link to the docs:
2021 Ford Bronco Owner Manuals
If you read back to what you quoted you will see qualifiers prior to my opinions such as "I find it" and "To me".
I find them useless for everything I have done so far in my travels.
YMMV, OP's MMV.
But again, I have not been to Sand Hollow yet to use the sand mode. I can see the benefit there where it does affect steering input, shift points, etc.
In respect to the terrain the OP described, I FELT any given "mode" was probably putting them in more peril, trying to monkey around with modes and finding they were not the settings they needed given the circumstance.
In perilous/dangerous situations (in my opinion) you need 110% of your concentration and faculties on getting through safely, not having to stop and dial in a new Mode in the midst of it because you find the one you tried isn't the right one.
Again, YMMV.
Much respect,
-Dave
