Sasquatch Practical Use Question
Megawatt
JO
Where the asphalt melts in the Summer
Lifted Rubicon usually off-road.
..... What is the offroading use case for the front locker, lift, Bilstein suspension and 35s? How much less capable in say MOAB is a 2d BD without the sas package? Where am I going to be frustrated that I didn't get the sasquatch? How far will a lift and 32s get me in this case?....
Here is my .02
There will always be an obstacle you will get stuck on, no matter the mods you have.
I prefer to drive over (bigger lift) vs drag over (slide on skid plates and differential housings). An inch difference can be what separates a fun trial from drama on the trail.
Using a locker for ten seconds can save you ten minutes on a trail.
Majority of off-road machines at places like Moab and canyon lands don’t even have one locker and they are out exploring and having fun all the time.
You may get stuck on BL stock and wish you squashed it and at the same time you may get stuck on a SAS rig and still not be happy.
If you can afford the SAS and not be bothered about the price tag then get it because it’s good stuff. But having the SAS package guarantees you nothing off-road.
DonM
Don
Northern Cincinnati
2021 4DR Base Sasquatch 2.3 in VB
Here is my .02
This is why I'm thinking just a stock Base 4DR, well with Aux Switches and Floor Liners. If I get into off-roading I'll farkle away!! I still may option the 2.7 though.
AcesandEights
Ace!
Oregon
DR650
The real difference is determined by how you use the vehicle. A non-Sasquatch model/trim is going to 95% of the places the other vehicle is going, but how often do you want to get to that last 5%? Do you drive 100% of the time to the 95% or do you want to drive 1% of the time to that last 5% extreme trail.
As others stated, that other 5%, the Sasquatch is mostly sold through marketing a dream, not based on actual need or necessity. If you've never been stuck, you probably don't need the front locker, but when you do, you do. Plenty of people have driven all over this country with open differentials, but when you've got a tire off the ground, or you're driving in slippery-as-snot mud, you'll wish you had locking differentials. Most people think they want to be a 1%'er, but they don't really want that. Do you though, do you really want to get through the most extreme trails? Otherwise, carry a small shovel and a tow strap, or traction recovery board and hit all but the most extreme trails.
You don't need the front locker or lift or 35" tires, unless you want to go where that last 5% go. In addition to that though, you need experience off road, because without the experience, lockers and 35" won't get you any further than a good driver on 31" tires and open diffs. It's the rider, not the bike, that wins races.
HoosierDaddy
__ Eric
NW. Indiana
I always tell people, you'd be amazed at how far my 69 Bronco on 33's and open diffs would take you.
If I weren't such a tight ass, I'd do Big Bend or Black Diamond on 33's , rear locker..... but for less money I can get a Base Squatch.... easy decision for me.
PDiddy
Paul
4Runner
I’ll be squaching mine for mostly looks and resale. It will go off road, but nothing extreme enough to need 35s vs 33s.
we plan on keeping the bronco for a long time and I think these Broncos will be more desirable, down the road, with the Sasquatch package.
Plus if my wife doesn’t like driving it with the 35s we can swap them out with the 33s on my truck. Actually, I hope she doesn’t like them! Wait a minute, my wife is going to have bigger tires on here vehicle than mine...
mrxg78
G
Cheshire, CT
FJ
Do I need the Sas with my BL to get up this
if yes then I’m all set.
Hoofnmouth
mark
N ca
ford focus st
First time i did the rubicon i was oped diffs 33s got beat up,next time lockers ,gears,35s 4in lift ,it made it so much more capable my girl drove most of the trail she said it was easy .
If you think you will want to go outside your comfort level anytime get the sas its a great deal and factory installed with a warranty.
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
You can have a shit ton of fun in Moab on 33's and a rear locker, just ask my Xterra. Fins n things, wipeout hill, seven mile rim are stupid fun.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
That’s some serious I don’t give a f*** stuff right there!
SevenT
1970 U15 Sport Edition; 2021 AMB 4 Door Badlands
That video was impressive. They were working that wheel and had the skinny pedal mashed.
dgorsett
colorado
F250, Mustang, Explorer
Exactly. Also, that extra 1.5" (or so) of lift on the Sas will get you closer to the midships ground clearance of the '69.
MaverickMan
Shane
My user pic is my stock height CJ-7 with 31" tires and open diffs at Moab. No you don't need Sasquatch. And also consider the traction control on the new Bronco will act like a sort of locking diff. So they won't simply behave like open diffs as on older rigs. But if you do need the Sas components for real use (or for the Walter Mitty aspect), I'd get the Sas package rather than build it later.
The only thing about your example is that your CJ on 31s is far better than a JK/JL on 31s. The standard Bronco even a 2 door is heavier, wider, longer, and lower(everywhere except the CJs indestructible belly pan). I even out wheeled a TJ on 35s with 6" of lift with my old 5" lift CJ5 with 33s and no shocks mounted. Traction control will help a bit but wont offset the fact that it has delicate bits underneath that were non existent in the CJs day.
PaddyNY
Patrick
Rockaway, NY
2022 Ford Bronco Badlands 2 Door
How will the 35’s handle on the pavement?
MaverickMan
Shane
Looked like I saw some locker or LSD action there.
