Sasquatch perch collars or Eibach HD springs?
TLO
Canada
youtube.com
2 door
I'm basically wanting to get my ride height/clearance back after being fully overland loaded (plus 13k pound winch).
I bottom out more on the stock Sasquatch Bilsteins, particularly at the front.
I was thinking 1" collars from BroncBuster (F/R) as an option but since the springs have to come off anyway, maybe swap in the HD (pro truck 2.0) springs from Eibach.
I think the springs alone give you some lift and with the 500Lb spring rate, I shouldn't sag as much as stock....?
Thoughts?
Fordsoldier
MIdwest
2024 Bronco 4 door Wildtrak high lux
I would go with Springs, I did spaces on my F150, and then took them off and did springs, ride was much better with springs.
I may look into the springs for mine, my wife asked me to drive it for a year before I get to crazy.
zyglyrox
Cory
Cleveland
‘24 BB Sas / ‘21 Bronco Sport BB
I always advise people away from spacers if they can make up that lift with actual components designed for more travel.
  • Like
Reactions: TLO
Pakman
Elbert
same here started with collars not run eibach springs
TLO
TLO
Canada
youtube.com
2 door
I have the Eibach springs. They are nice.
Did you go with the HD springs or the regular Eibachs?
Both offer some lift over stock Squatch?
I just wanna basically get back (and maybe add an inch) over where I was before all my gear loaded up. 👍🏻
RoseLane4
PA
Subaru WRX, Subaru Forester
Do yourself a favor, invest in the springs!
Don’t think twice!
Lak34ers
Troy
Seattle
Thoughts?
Or 6100s much better than SAS 2.0s which will eventually fall apart a d don't ride as well.
Happytown
Ryan
Zachary, Louisiana
2013 F150 Eco SCREW 4WD
Mostly just following this thread but here's what I can contribute: I put the Eibach Pro Truck Coilover 2.0's on last year, with the standard springs (fronts are 450#'s). I have a winch up front now which has me putting the fronts at max preload and the rears at almost minimum preload to get the ride height/attitude I want, but it still is a little low in the front and dives a little at stops. I just got off the phone with Eibach. I can get new HD springs and swap them out at $125 each, which would give me the choice of going with a 500# or 550# spring. OR get whole front coilover assemblies for $357 each, but only available with the 500# spring. I'll probably go with buying the 500# springs, but I would like to know for sure that this will be enough to pick the front up enough and allow me to back off the preload.
TLO
TLO
Canada
youtube.com
2 door
Is Eibach selling the coil over 2.0 kit with those higher rate spring now?
So weird that the front/rear rates seem so out of wack
Happytown
Ryan
Zachary, Louisiana
Yeah, the standard 2.0 springs on the front are 450#. You can get the HD full assembly which is the 500# spring (this contradicts what someone else said in this thread, they said the HD came with 550# front springs, just relaying what Eibach told me). Eibach told me you could get the 550# "springs only" but would have to disassemble your kit and swap them out yourself.
  • Like
Reactions: TLO
