- T
- Mar 11, 2021
- 8
- 308
- 324
- Berkeley, CA
- 2023 Badlands, 2013 Toyota Highlander, 2000 Miata
- Badlands
That power distribution box in the rear is rather slick. Even though it says Audio, I presume you plan to use this for power? The 0AWG goes to the battery?Audio System, Accessory Infrastructure, Additional Auxiliary Switching
For Starters, thanks to all out there for all of their efforts and meticulous write-ups/documentation/video. Principally to @RagnarKon, your write-ups and YT videos were fantastic.
Initially I went with the following setup:
- Kicker Key 200.4 to drive the front stage
- 4" JL Audio Coaxils for the dash
- 6.5" JL Audio Coaxils for the rear still driven by the factory amplification
- JL 8" sub
- JL 250.1 Class D AMP
Having grown up a car audio freak, I was disappointed with the above; especially with tops off. IMHO it didn't come close to the factory setup in my 2014 Super Duty. Here is the final build list I am VERY pleased with. Probably overkill for most but it sounds great even barelling down the highway tops off at 80mph
- JL Audio XDM600/6
- JL Audio C1-650se Componets (components with tweeters in dash and drivers in kicks are the money as many have indicated)
- JL Audio C1-650x Coaxils For the rears and Mabbet enclosures to fit them
- JL Audio JD250/1 Subwoofer amp
- JL Audio 8W1v3-4 Subwoofer in the stock enclosure with some trimming
- Ran Aux/all new speaker cables back to the Amps while I was bringing power back
- Since I was running it, went ahead and did 0 gauge wiring kit and a distribution block strategically mounted behind the passenger side access panel in the cargo area for easy access/future accessory power. At $70 the 0 gauge kit is a STELLAR deal.
Despite having upfitter switches, I put an eight switch auxbeam in as well knowing the upfitters would run out quickly. Some under hood wiring shots. I've used cable sleeve and heat shrink on everything. All connections are waterproof & soldered using these awesome connectors.
Conveniently the included bracket worked great to mount to the battery
Trimmed the back of the terminal cover to accommodate wires:
@Melzingah here's the audio upgrade!
How does the DV8 overhead molle work with the Bimini top? I have a Jtops Bimini which goes edge-to-edge but I presume about the same height. I was wondering if the Bimini interferes with access to the overhead shelf.
Thx for the details and links to products. Great thread OP!
