Rust spots EVERYWHERE
ruddawg
Rudy
new jersey
23’ Bronco wildtrak , 13’ Audi A6
Hello I have a 23’ 4dr and noticed rust spots all over the vehicle. Hood, doors, behind fender flares, tailgate, above rear tail lights etc.
Anyone else have an issue like this? I ran it through a car wash and they’re still very prominent.
Ford Bronco Rust spots EVERYWHERE IMG_1594
Ford Bronco Rust spots EVERYWHERE IMG_1595
Ford Bronco Rust spots EVERYWHERE IMG_1597
heavyD
Calgary, Alberta
2025 Badlands 2-Door
That's just industrial fallout from the roads. Very common in places that get snow in the winter where there are snow plows or other means of snow removal. Just apply some Iron X in the spring with a 2 bucket wash and they will go away.
tonytexchappy
Tony
Texas South Plains
08 Mini Cabrio, 22 Maverick
After you Iron X it, clay bar and wax it after. You're welcome.
This. But don’t use a traditional clay BAR, use a clay TOWEL. Newer tech and less chance of needing to polish afterwards.
timbits588
WNY
2017 Expedition EL Limited, 2023 F-150 Lariat, 2023 Bronco Wildtrak
Does it work as well? Serious question, since I've never used one. I've done clay bar plenty of times, but never tried the towel...at least, not yet.
tonytexchappy
Tony
Texas South Plains
Yes, they work very well. Took me a long time to make the switch as I’ve used the traditional clay bars for a long time. finally was convinced to try them and quickly saw how well they worked without marring.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
This, or equivalent product, should do the trick to help remove them:
Ford Bronco Rust spots EVERYWHERE Screenshot 2025-02-20 at 2.12.13 PM
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
I use Meguiars mild detailing clay bars, and Meguiars "Final Inspection" as my spray-on lubricant.
Imaginary Friend
Southern MN
A passel of Fords and a Jeep JL Rubi
I didn't know the towels existed until this post, I'll give one a shot. I'm a clay bar devotee, so it should be interesting.
KyleNL
Kyle
St. John's, Newfoundland
Check out this link, I brought my bronco in for the paint flaking off the top off my mod bumper and they called it abrasion damage and wouldn't cover it based on this paint issue identifier. But this looks like figure #21 which has limited warranty coverage so worth showing dealer. and watch your door jam bottoms and tailgate and hood, I've had mine repainted twice under warranty from the paint rubbing off.
https://www.fordedgeforum.com/topic...s-vehicles-paint-and-bumper-concern-analysis/
Herbie
Alex
Cleveland OH
2022 Badlands
As @604Bronco said above, that is more than likely iron and fallout either from a transport and it was never dealt with or just from normal driving. As mentioned, just find a decent Fallout and Iron Remover. Give your car a quick rinse first (in nicer weather), spray it with the fallout remover and let it sit for 10 or 20 minutes (follow directions on the bottle) and that stuff will all turn purple and look like it is melting away. Stuff smells like sulphurous eggs btw. Then use either one of these clay bar type products people mentioned and or just give it a nice washing (depends on how well the remover worked and/or how stubborn some of the spots were). I would be rather surprised if it was actually rust. Not that aluminum can't rust, but it would be rather unlikely for you to have that happening all over your vehicle, more likely the latter.
This is another one:
Ford Bronco Rust spots EVERYWHERE 1740148695021-hj
