Rust Proofing the undercarriage
Bdisco
Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
‘88 911,‘15 Chevy 2500, ‘24 Acura Integra Type S
bytheway
Brice
Louisville, KY
Hoping you used something oil based like Fluid Film.
GToddC5
Todd
South Jersey
www.bronco6g.com
Bdisco
Bdisco
NHOU
https://nhoilundercoating.com/
Have it on m 2015 Chevy. So far so good. I tried Fluid Film but that actually softened the factory undercoat to the point you could scratch it off with your finger nail.
Ford Bronco Rust Proofing the undercarriage 088ED058-5A1B-4173-839C-17033F398CB0
My 2000 7.3 F250 would still be with us as the motor only had 120k on it if rust hadn’t taken her before her time. Gone too soon RIP (rust in pieces).
Bdisco
Bdisco
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
I ordered some fluid flim. It's waiting in my garage right now.. Have you or anyone used this product and can give some protips for installation?
Bdisco
Bdisco
Any idea of the rough cost from something like this?
$1400, not cheap, but Is a 4 day process. Tough being without my new ride for so long, but hopefully worth it if it is protected from the crap they coat the roads with now. While the roads maybe safer from snow and ice our vehicles take a beating.
Bdisco
Bdisco
I tried a small section of Fluid Film on my Chevy and found it softened the factory undercoating to the point you could scratch it off with your finger nail. I ended up using it on my plow instead.
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
Interesting... Glad you warned I'll be sure to test before going full send
JT58Bronc
JT
Fl
2022 Bronco, 1987 Chevy Squarebody 4 X 4
I have used the combination of rubberized undercoating and primer/painting on vehicle frames in the north driving in very salty roads. You have to make sure you apply it to a very clean surface- remove all traces of rust, etc. If down to bare metal primer first. Yes some of the undercoating chips and comes off over time and I would inspect the frame after every winter and do a little scraping, sanding and re-undercoating touch up. I found that even better than the undercoating is to use truck bed liner spray.
Gamecock
Fluid film is fantastic...works much better than "professional" methods in my experience, even on my Toyota frames which rust when you look at them. Just apply it liberally on everything underneath before winter and then again before summer, and it works great. 2x a year worked really well for me. Great stuff, and cheap and easy.
bytheway
Brice
Louisville, KY
Bdisco
Bdisco
Test a small section first. Might have just been an anomaly with my Chevy.
Worked great on my Fisher X Blade plow.
