- #31
I only masked off the brakes.did you mask off the frame mounted sensor mentioned in this post?
https://www.bronco6g.com/forum/threads/warranty-denied-because-of-fluid-film-undercoating.55824/
ThisI take my vehicles to a place in Michigan (Henderson Bros.) where they take trim and door panels off to coat everything. For a couple days, there will be drops of the undercoating wherever you park. They advise people to drive on a dusty gravel road after undercoating in order to expedite the curing/excess dripping.
Why not use POR15?
You can even brush it on....
Quite a few reasons. #1 is It isn't lanolin and you can not get the proper mill spec by brushing a paint based system. As I mentioned before I used to do this for a living in a big commercial facility utilizing an electrostatic paint system that would cost anyone $1000's of dollars vs $30 and an hour at home.
Lanolin is an extremely effective, pocket friendly and the most maintenance friendly way to treat.
I’ve been spot treating rust as I find it with this product: https://por15.com/collections/3-step-rust-preventive-system
Not a perfect solution but makes me feel a little better and certainly looks better than rust. It dries hard so no worry about it coming off or collecting debris. So far it’s been extremely durable. Dries a little glossier than the rest of the underside finish but once it has a little dust on it you don’t see the difference. Plan is to go under the Bronco 1-2 times a year and treat whatever rust I can see. Good option for someone not looking to coat the entire underside.
Looks good. I used fluid film on mine. Similar look. Excited to see how it works this winter!Wanted to show how I undercoated using PB Blaster's new surface shield product. This is comparable to fluid film and woolwax- it's lanolin base so it stays oily and does not dry and harden- does not crack off.
Previous career I used to electrostatic spray rust preventive on truck frames and I can tell you I personally shy away from such products due to cracking and peeling issues. Long story short, if you cannot get a specific mill spec on the coating it will break off so more is not better. You need a professional commercial setup and tools to do this job correctly.
I live in the rust belt and work in a steel mill- This is the ultimate way to destroy anything so this will be the test of all test.
I took delivery of my base Bronco two days ago and the very next day I coated the entire frame, driveshaft, nuts and bolts, the inside of the door drains and inside all the frame holes with the surface shield. The only thing I masked off were the brakes. I used the T9 on the door jams, wheel hubs and lugs. It takes very little of this product and it is used in aerospace applications.
I will keep this updated as winter and the years progress.
It took 2.5 cans of PB Blaster surface shield to treat a base 2 door= $30
You could coat everything in T9 if you really wanted a less than oily look, but consider it's $120 for a gallon off amazon.
Areosol cans are $20 but this can also be used to clean off everything so I'd be wary of getting it on certain connectors and sensors without properly masking them first and not having a spray booth. Overspray isn't much of an issue with the PB blaster just place a tarp underneath and it's easy cleanup and you're done.
Happy winter everyone.
The three step stop rust system.The link shows a bunch of different “systems”
Which one are you doing?
Check out @repairgeek on YouTube. He's been using the Surface sheild for years and has some great things to say about it. He did mine the day I brought it home.Worth it. Did my wife's 2019 ranger for this upcoming winter after noticing how bad it was starting to get. Had enough cans do do the bronco as well. Want to get more thorough next time. I appreciate the heads up.
That's what led me to the surface shield, as well as the winged adapters for applying. Through my limited research, including his videos on the subject, PB blaster was worth the shot.Check out @repairgeek on YouTube. He's been using the Surface sheild for years and has some great things to say about it. He did mine the day I brought it home.
That looks pretty useful. I don't think you can get away from gravity feed, like I imagine the wool wax gun would be the same. Just watched a quick video on it. How often would you say you refill? I assume there are attachments, or at least you can make a fitting work for hose with 360 tip for deep inner frame spraying.
Not having to drag air hose through overspray on the ground would be nice... Also, the utility of different products going through the spray system would be useful. Weed killer, deck stain, liquid fertilizer...
It’s hose free, you can pressurize it, like putting air in your tire. I usually put about a quart in it and fill it to 80psi and can spray the underside in about 5-10 minutes. It has a pretty good spray pattern, I take the tip off and removed a needle to get more of a narrow spray pattern. Used it on all my vehicles for the past 8 years.
