Running the wiring for A-Pillar ditch lights
Droz
Birmingham Alabama
2024 Bronco
I did a few searches but it did not return exactly what I was looking for. So.....
I am not concerned about connecting to the upfitter switches but was wanting to see how many of you ran the wiring harness from the ditch lights to under the hoot for the final connections. Pictures would be great. Even in Crayon!!! I have two sets of wires to run since I have double lights mounted.
Ford Bronco Running the wiring for A-Pillar ditch lights 6D5094F1-0360-4F63-AAA6-6560077AFE0F
Jazer
Jessica
2.7 OBX
Ford Bronco Running the wiring for A-Pillar ditch lights 1000001322
Mjasi3
Chicago
I ran mine through the weatherstripping at the back of the hood…
Ford Bronco Running the wiring for A-Pillar ditch lights IMG_6889
Ford Bronco Running the wiring for A-Pillar ditch lights IMG_6890
DeathValleyBob
Bob
Rolling Hills Est. CA
2003 Wrangler Rubicon, waiting for Badlands/S
My ditch lights came with a nice waterproof connector. Way too big to thread through the tiny cowl slot. Easy fix: remove the larger screw at the cowling accessory mount location, only on the side involved. Use a plastic panel remover tool to pry up the plastic cowl piece. Only pry/warp it enough to clear the connector. The connector will appear near the hood hinge inside the engine compartment. May take a couple of tries to get it in the right space. When routing the connector/cable be sure to secure it away from the hinge bits so it doesn’t get crushed when the hood is closed. Lower the cowl back into place being careful that its tabs on the forward edge go back into their slots. Replace the screw and repeat for the other side. Use some of the woven cable cover strips and some cloth cable wrap for a professional look.
Mean Green
Bill
Warminster, PA
23 Ford Bronco 2dr Badlands Sasquatch
Ran them through the small hole.
Ford Bronco Running the wiring for A-Pillar ditch lights IMG_3843
DeathValleyBob
Bob
That works well if using a connector-less cable. But then you have to mess with more solder/crimp joints. My lights came with an excellent harness and waterproof connectors. It included a relay and remote switch pod. The current draw was well within Upfitter 3 capabilities, so I just cut the wires before the relay. BTW my MY2025 has a larger wire for Switch 1, it is also yellow/red rather than its predecessor’s yellow. Some other color changes too.
Footer
NJ
2023 Bronco
Does anyone just notch or drill the cowl ?
CalvinT
Calvin
Phoenix, AZ
Ouch! Do a search on here. There are a couple of ways to run the wiring without notching or drilling the cowl.
Footer
NJ
2023 Bronco
Thanks.
Just thinking a small notch at the cowl seam would do.
CalvinT
Calvin
Phoenix, AZ
Some pull up the cowl and run it past the weather stripping and replace the cowl.
It might be worth you time to go to some meets and see how others have routed their wires.
BlackDog
MI
F Series
Yup just did that with mine. Hope it doesn’t leak. Everything popped back into place and looks good. But water finds any way to get in.
Big Red Rocket of Love
2024 Ford Bronco
I hated the idea of popping my hood and seeing more wires in there, so I separated the cowl and tucked my ditch light wires inside all the way across, then snapped the cowl pieces back together. Pretty simple and a clean looking install.
~Steve
TiKi-Bronco
Land O Lakes FL.
2024 Bronco
I just did mine yesterday. I used the SPV Performance kit. It came with the connectors unpinned so it was easy to fish the harness from engine compartment to the bottom of the windshield. Assembled the connector and plugged them in. I also used cloth cover over the harness.
Ford Bronco Running the wiring for A-Pillar ditch lights 1000011169
Ford Bronco Running the wiring for A-Pillar ditch lights 1000011144
