Rubber breaking around window controls
Razorback
Dallas
Lincoln MKX
Has anyone else had an issue with the rubber breaking/tearing from the window controls? I just noticed mine, and a complete bottom section came off the driver's control. Half of the passenger is now missing. If anyone has removed the center console, I'm wondering if it's an easy fix.
Ford Bronco Rubber breaking around window controls IMG_20230420_171522
Ducati1098
I have never seen this, so I won’t be much help with that.
However, I do know that the switch assembly just pops out with the help of a trim tool. No need to remove the console.
Razorback
Razorback
Dallas
Lincoln MKX
Is someone violently pulling on that switch?
Nah. Just holding it. My thinking is the friction from letting go vs moving fingers down and then out.
Razorback
Razorback
Dallas
Lincoln MKX
Perfect. I'll just have to order the assembly and replace then.
Razorback
Razorback
Dallas
Lincoln MKX
Although a simple fix I'm sure, why not have the dealership warranty it?
At first I thought about it, but didn't want to worry about them denying it after having it for a week. Plus both times I had them do the front diff leak, it took over 2 weeks. I just looked the part up online and it's $25. I could probably have it done well before the dealership.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
That's a lot cheaper than I thought it might be. I wonder if you can have them order the part (under warranty) and you swap it out yourself? No harm in asking at least; I'm sure it's plug & play.
swooshdave
Portland, Oregon
Mustang
Warranties don't work that way. They have to do the install.
Toccoa
Isuzu Rodeo Sport
Story checks out. 😁
Ford Bronco Rubber breaking around window controls 1682091930578
Razorback
Razorback
Dallas
Lincoln MKX
Yep, easy removal and has just one plug harness in the back. I'll just have local dealership parts order it I can have it brand new in no time.
Ford Bronco Rubber breaking around window controls IMG_20230421_104859
604Bronco
British Columbia
www.bronco6g.com
Worked for me recently - I had a Ford accessory that needed a part replaced, and the Parts department had it shipped directly to my house and allowed me to install it myself. The Parts advisor did mention they may have to install it in their Service department, but didn't turn out that way.
It may vary for certain things for sure, and you may be right, but no harm in asking since it's such a simple plug & play.
Razorback
Razorback
Dallas
Lincoln MKX
It was $28 for the entire unit so I just used some of my 300k pass points and it will be here next week. Easier than dealing with the dealership. Still surprise it was so cheap.
DVAnt
Anthony
Honolulu
none
I am having this same problem with mine. The driver's side just rolled off with I was putting the window down. Good to know it is a cheap part and easy fix.
Razorback
Razorback
Dallas
Lincoln MKX
part number for 4 door: M2DZ-14529-AB
