Rough Shifts since oil change
not on the rug
NJ
2024 Wildtrak. 2011 BMW X5M. 2024 Nissan Pathfinder Platinum
2024 Wildtrak. 14k miles.
Did my 3rd oil change a few weeks ago. The first 2 were done at a buddy's shop and I confirmed that they didn't do the Priming process after the changes were done. Amsoil used. No issues.
I finally had some free time the other day I changed it myself. No issues. I had seen a YT vid where the guy did the priming afterwards so I thought I'd do it. No issues. Ever since then the Bronco tranny is not the same. In particular, the upshifts are rough and sometimes it feels like it's holding in the gears for too long instead of downshifting and "bogging" the tranny.
No codes/lights. Nothing else was touched. Nothing out of place.
Even if the priming process somehow reset the tranny's learning process, I've driven several hundred miles since and it should have re-learned by now. Make it make sense.
Any ideas?
@Ducati1098
MDrums
Tampa
Bronco Raptor
You changed your oil...then your transmission started shifting weird but you did not change the transmission fluid? Trying to understand this as oil and the trans fluid do not mix and mingle between the engine and trans.....
not on the rug
not on the rug
NJ
Check your oil level, iirc this happens on overfill.
That was my thought initially. 6qts in for the change. I checked it after about a week of the nonsense. It was right in the middle of min/max.
not on the rug
not on the rug
NJ
Yes. Didn't touch the tranny fluid or tranny in any way. Didn't touch anything at all other than to drop the skid, pull the plug, pop the top, change the filter and then button it back up.
MDrums
Tampa
Bronco Raptor
Ok thanks for the reply just wanted to make sure I understood you and we are on the same page...yeah that is utterly crazy....I wish I knew the answer for you though. Bummer
not on the rug
not on the rug
NJ
Thanks. I am scratching my head over here.
It does it in sport mode and it nornal mode. Doesn't matter if the oil temp and trans temps are cool or of the truck is warmed up.
MDrums
Tampa
Bronco Raptor
I have done 2 oil changes on my Raptor so far in 2100 miles...sending samples to Speediagnotix...no difference in how it is running so far. Probably coincidence
Ducati1098
It’s gotta be a complete coincidence, there’s nothing you could do changing the oil, or even using clear flood mode, that would affect the way the transmission shifts.
I would just bring it to your dealer as a normal transmission concern.
not on the rug
not on the rug
NJ
Thanks. That's exactly what I was thinking. Just dreading bringing it to the dealership. I tend to avoid those places like the plague. It's a complete tossup as to which tech you'll get and if they can or can't replicate the issue.
Ducati1098
Understandable. You’re more than welcome to take a trip here to Illinois, I’ll get it fixed up for you 😂
Stromski
Walter
Annandale Virginia
2025 Bronco 2 door
I had my first oil change at the dealership. When I pulled out of the bay, my takeoff was very abrupt.
I attribute this to "Midget Mechanic Syndrome". This is when you go for service and the seat is slid far forward by the lot jockey. The angle of my leg to the clutch was totally different than in my normal driving position.
not on the rug
not on the rug
NJ
Would it be worth it somehow to disconnect the battery and see if it will relearn because somehow, someway that is actually the cause?
