Roof Leaking
Bmason401
Exton, PA
2024 Ford Bronco 4DR
Hello,
I just bought a 2024 Bronco Wildtrak 4Dr and it has 300 miles on it. Every time it rains I get water inside. Can someone assist me with getting someone to help this issue. I assume there's a sealant issue.
I saw sometimes Ford responds on here.
Thanks,
Brian Mason
AK SNO RIDER
Ty
Alaska
Ford no longer monitors this forum, and they weren't exactly helpful when they did.
If you can't narrow down where it's coming from yourself, your best bet is unfortunately to take it to the dealer. It's brand new, you have a warranty.
First thing I'd do is remove the roof, visually inspect the seals, and then put it back on and make sure it's seated correctly. Could be as simple as a wonky factory install.
Bmason401
Exton, PA
Thank you for the response. I am going to schedule a service appt at my local dealer to have it checked out.
WheresMyBronco
Los Angeles
2023 Badlands
Where are you finding the water in your Bronco? Might help us narrow it down a bit
Bmason401
Exton, PA
it came in through the driver side right above the visor and was leaking down to the center console and on the dash.
Smocaine
DFW, TX
Cervelo Caledonia
Have you tried taking your panels off and re-seating them? It sounds like the seal between the two front panels may be bad or just badly seated.
If it is not visibly damaged, you may have luck with a seal lubricant product. I hear Honda's grease for minivan door seals is very good.
BroncoDave24
East Tennessee
'61 Falcon, '87 F150 XLT Lariat 5.0, '01 F350 7.3L, '24 WildTrak
I guess I have been lucky with my '24 Wildtrak 4 door hardtop. No leaks , yet! I would take the front panels off (as per the owners manual) and make sure the seals are not folded or out of place. Put the panels back in the correct order as well. I would hold off on the seal lube until your dealer looks at it. Let us know what you find.
Bmason401
Exton, PA
Thank you guys. Made an appointment with a leak specialist through my local ford dealer. Will know in a couple of weeks when I bring it in for the appt.
Appreciate everyone reaching out.
jay212
Jay
Westchester
Hello,
Thanks,
Brian Mason
Hello,
Thanks,
Brian Mason
Hello,
Thanks,
Brian Mason
I’ve got the same year and model bronco, and I’ve had water leaking in the middle of the two caps. I took it to the dealership & ford knows about it, however it’s not a recall as of yet. They replaced the weather stripping and added a sealer. I haven’t gone to a car wash yet since it’s been raining here.
Bmason401
Exton, PA
That's my guess too. It's likely something in between the two caps. I am wondering if this is a known issue with this roof, which is the Color Matching roof to the body of the vehicle. I noticed the roof panels inside look different than the ones on other 2024 Broncos I have seen that are NOT color matching. Missing that carpet like looking sound deadening material that my wife has on the roof panels.
BroncoDave24
East Tennessee
Mine came down the line early May 2024
Mjasi3
Chicago
Bmason401
Exton, PA
Mjasi3
Chicago
Hi Mike,
This is a great PDF. I am going to print this out.
This community is the sh*t! Appreciate everyone's help.
no problem, especially if the dealer appt is 2 weeks out, definitely look att he seals and put em back on.
Lankyhank888
LankyHank
TX
youtube.com
2025 Ford Bronco Raptor
How did this ever turn out? I’m curious because I’m currently dealing with a roof leak on my Bronco as well. Mine has been back to the dealership multiple times, and even after repairs I’m still chasing the issue.
I’ve been documenting everything and put together a video showing the leak and water intrusion into the cabin. If you’re interested, here’s what I’ve been experiencing:
I’d be interested to hear what the final fix was on yours and whether it’s stayed leak-free since then.
