Rockslide Engineering Steps - GROUP BUY has started!
Deano Bronc
Dean
Winona Lake, IN
2022 Badlands
Mine been sitting in the garage for over a year and finally got to install them last Sunday. Spent the whole day but could greatly reduce the time doing it the second time. I still need to put on the lights but I don't think that will take long. I was amazed how beefy this setup is. Compared to the factory rails, its a night and day difference.
A couple of things though. It appears that I received the wrong grommet that goes in the floor. Mine is just a rubber ring and it looks like I should have gotten a solid one. Anyone else get the wrong one?
I think these steps really help getting in the Bronco but I'm still trying to figure out the best way to get out of it. Every way I've tried seem awkward or my leg/pants rub on the upper black portion which will either have mud or salt all over it at some point. Just doesn't feel natural any way I do it.
Jhuff
J
Toyota Tacoma and DR650
Yeah that was common on the first batch. I emailed their support and they sent the correct grommets out immediately.
I have a leveled badlands and the stup up is perfect for me ... Only problem is if they ever break or get stuck closed, they will be awkward to climb over.
Benzo
Ben
Bay Area CA
too many to list
I was part of an early group buy purchase and while waiting for my bronco, I saw a lot of other sliders coming out. I was contemplating if I made a mistake with the early purchase, but when I finally got my bronco I was very happy after installing the RSE sliders. Each time the door opens for my passengers or myself, I know I made the right choice. Also when I look at how other sliders mount, I feel so much better about how the front and rear mounts use the frame to body mount points.
mdfilip
New Hampshire
20 Shelby GT350, 22 Bronco BL, 29 Ford Roadster
Anyone have any issues with noise / play in these? I installed mine and immediately noticed the drivers side was much louder when closing, I also noticed that when down the drivers side has play side to side and from to back but the passenger side is solid with no play at all. I found one of the internal brackets holding the rear pivot arm to be loose but even after tightening the bolts there is still play and the noise is the same. Any adjustments that would fix this or did I get a defective unit?
If you watch towards the end of the video you can see the bracket move but like I said I tighten that and the movement is still there.
Herbie
Alex
Cleveland OH
2022 Badlands
https://www.dropbox.com/s/uhjj023aygh2cav/IMG_8504.MOV?dl=0
I have been using them for six months, mine both have a little play. I wouldn't call that defective, just the way they are made. As far as the clink when it closes, some of the motors seem to be stronger than others and retract the step with more gusto. If it bothers you give them a call and they will send you these little plastic gussets that go on the metal cross members up inside the housing so when the step rises, the arms come to rest against the plastic/rubber gusset rather than having the metal on metal clank. That being said, what you are experiencing is not a defect, just a function of how these 75 pound metal on metal steps operate. Their techs are very good at trouble shooting with you and willing to help.
Jebster
Honda ridgeline
I was just about to contact RSE with a similar issue. My passenger side step has some front to back movement where the driver side is rock solid. I was wondering if there was some adjustment that could be made.
I also wanted their advice for a completely different issue. My driver side has developed a very loud creak noise when I step on it. Very annoying. I know it isn't the step itself but curious what I can do to eliminate the noise. Do I have bolts too tight? Not tight enough? In this video it is in my garage which amplifies the sound.
mdfilip
New Hampshire
Exactly the same issue.... Has to be a fix for this, it can't be normal. I could see if they all did this but with one being perfect I know it's not. I'm calling RSE tomorrow and report back what they say.
The creeping noise seems like the brackets may not be tight enough. I'm sure you checked that but from the video that's what I would check
Jebster
Honda ridgeline
I'm going to check the brackets again. Was under it the other day tightening things because that is what I thought but didn't seem to help. And I'm not getting that noise on the passenger side or even when I set on the back of the driver step
mdfilip
New Hampshire
I would like to report RSE does not mess around and were very responsive to my email and it looks like one of mine might have an internal problem so they are sending out a replacement! (y) I will report back once I replace the step but so far I am extremely happy with both Doetsch Off Road and Rock Slide Engineering
Jebster
Honda ridgeline
I agree on the service. They already responded back. Sending out shims for the play in my passenger set.
