right rotation when braking hard?
brkdncr
Southern California
Toyota 86
I was on a soft sand/dirt road this evening and a rut appeared so i braked fairly hard. The vehicle rotated to the right. the steering wheel didn't feel like it was pulling.
I tried it a few more times at different areas, going uphill, etc. I noticed this a little bit on pavement but didn't think much of it.
I'm thinking one of my brakes on the left side isn't braking? I cna't think of what else it could be. no noises when braking.
2023 2dr w/t, 2k miles.
I won't be able to take it to a dealer for 2-3 weeks so this may remain a mystery unless someone is aware of a known issue.
HeliPilot
Kenny
CT
2022 2.7L SAS
Brake Proportioning valve sending greater pressure to pressure one of the wheels maybe???
Dlars99
Dan
2023 Black Diamond
Have you tried bleeding the brakes?
brkdncr
brkdncr
Southern California
Toyota 86
I’ve done nothing except complain and criticize so far, but that’s a good idea. I’m going to schedule shop time since it’s still under warranty. If I bleed the brakes and it turns out to be a faulty line I don’t want them to be asking why I was bleeding them on a brand new car.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good morning! Could you privately message us with your VIN and the name and location of your Ford dealer so I can look into this brake concern for you? Thank you!
brkdncr
brkdncr
Southern California
Toyota 86
Dealer said they can’t reproduce the issue and won’t bleed the brake. They’ve asked me to come pick it or drive with a tech.
I’ve asked them to check on the case number that our local FMC social rep assigned to me.
LockedBronco
Frank
PA
1972 Bronco
brkdncr
brkdncr
Southern California
Toyota 86
How fast and what do you mean by rotated on pavement?
Any speed really, but it’s noticble the longer it takes to slow down.
And it rotates to the right like it’s turning but there’s no pull in the steering wheel. The rest end is simply coming around.
Imagine braking with no left rear brake.
LockedBronco
Frank
PA
1972 Bronco
You could use a temperature gun.
If you get it to act up, go around and check temperature of the rotors
LockedBronco
Frank
PA
1972 Bronco
Also if it started after off-road possibly underneath something may have come loose/bent or broke. But dealer SHOULD have found that.
brkdncr
brkdncr
Southern California
Toyota 86
It’s been like this from 0 miles. I noticed it while driving around on concrete but assumed it was road crowning.
LockedBronco
Frank
PA
1972 Bronco
In that case you should not be driving it until issue is resolved.
brkdncr
brkdncr
Southern California
Toyota 86
You would think the dealer would take a reported braking failure more seriously to avoid the legal ramifications but here we are.
I’m taking a tech for a drive this afternoon to try and reproduce the issue for them.
WeirdFlex
Ethan
Los Angeles
Acura TL, Honda CR-V, MG Midget
I would assume that it is a brake issue, but I’ve also experienced a good bit of rotation due to what I suppose is the pan-hard bar in the rear. This only occurred when I had hop-skip-jumped over a patch of potholes.
