Howling when turning to the right after driving a while
Luthier419
Shannon
State College, PA
Bronco, F150, Fiesta
my ‘23 B/D with steelies & 30k miles just started making a howling noise when turning right today.
started after coming down a long, steep mountain highway.
I can also feel a very high pitched vibration in the steering wheel when it happens.
Pretty sure its brake related as it goes away when you hit the brakes.
Also pretty sure its heat related as well cause it doesn’t do it when cold or after long stretches of not using the brakes on the highway.
Started after one long downhill, quit after a long highway ride and started again after another downhill mountain road.
Its NOT a grind, i know what failed pads/metal to metal sounds like, its a howl, like maybe the pads are dragging.
Rotors are smooth, no gouges.
will change pads asap.
just wondering if this is a known issue. Like the caliper pins need lubed and the brakes hang up?????
I don’t remember hearing this from another car and i’ve had a lot of POS high mileage cars over the years!!!
F-Spot
SoCal
Tesla, FJ
My first guess would be wheel bearings
Area51BS
Ron
Badlands non SAS 4dr 2.3
Would a cheap infrared thermometer maybe give a clue?
Luthier419
Luthier419
Shannon
State College, PA
The center of the steelies are hot, i can say that! Ill stop and get my laser thermometer on the way home and see what the actual temperature is
Luthier419
Luthier419
Shannon
State College, PA
Maybe…. But Ive had bearing go several times before and it made noise wether the brakes were on or not.,
But it could be the bearing and the rotor is amplifying the noise when the caliper is not hushing it.
RoseLane4
PA
Subaru WRX, Subaru Forester
it may be a stone stuck between the rotor and disc (brake) caliper
